1.3 Gain to Draper M2500? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-09-2000, 07:58 PM - Thread Starter
mraub's Avatar
I currently use a 56x96 16.9 Stewart 1.3 gain screen with my Sony VPG 1272Q. If I change to a similar sized Draper M2500 how much difference am I going to notice? Is it going to be "WOW!" or "maybe I see a little more brightness?"
MIKE
MIKE
For every complex problem, there is a solution that is simple, neat, and wrong.
--H. L. Mencken
mraub is offline
post #2 of 2 Old 03-10-2000, 01:43 AM
Dean McManis's Avatar
Mike,
I went from a DaLite 1.3 gain screen to a Draper M2500 screen and it was visibly brighter, and I thought that both the color and contrast was also improved as well.
You should have Draper send you out a sample 8" X 11" piece of the material and you can hold it up to your screen to see how it looks comparatively.
-Dean.
Dean McManis is offline
Closed Thread Screens
