What is the advantage of a Perforated Screen - AVS Forum | Home Theater Discussions And Reviews
Old 05-14-2000, 02:41 PM - Thread Starter
paulh's Avatar
Can anyone please explain to me what advantage a Perforated Screen would be or having a screen at all. At the moment I am just using some the bvack of some posters. Use have just bought a CRT projector.
Any help would be of great use
Thankyou
paulh is offline
Old 05-15-2000, 02:04 AM
Dean McManis's Avatar
Paul,
Two questions.
1)Perforated screens (like those in a real movie theater) allow the speakers to be placed behind the screen. This helps merge the sound with the picture, and helps if you have limited space, and can't fit speakers above, below, or beside the screen.
2)Traditional screen material is designed for a flat, even, surface for reflecting the projector's light to the viewer.
Different screen materials have different attributes that can help offset the shortcomings or different projectors with more brightness or a wider viewing angle, or different configurations.
-Dean.
Dean McManis is offline
Old 05-15-2000, 02:57 PM - Thread Starter
paulh's Avatar
Cheers Mate
paulh is offline
