I have a manual screen - what this I've read about tensioners? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-01-2000, 02:23 PM - Thread Starter
paulh's Avatar
I have an 8 foot manual screen which as you probably know has a few slight folds in it when its down. Ive seen a few posts talking about screen tensioners. What are these tensioners and will they give my screen a nice flat surface?
Any help would be most welcome.
Cheers
paulh is offline
post #2 of 3 Old 06-01-2000, 07:37 PM
Andrew Low's Avatar
Check out http://www.scubatech.com/ Don has a really neat idea for tensioning his manual pull down.
A tab tensioned system is the way most screens are done commercially -- but there isn't really an easy way to retrofit this to an existing screen. Essentially what tab tensioned gives you is:
a) A really heavy bar at the bottom of your screen
b) little "tabs" along each side of the screen in a slight curve (wide at the top, narrow in the middle, wide at the bottom.
c) through the tabs is a wire that pulls the tabs tight. The heavy weighted bar at the bottom make certain the wire it tight and pulling the screen to either side.
Thus -- tab tensioned. You can see pictures of this on the Draper website: http://www.draperinc.com/projection/...tensioned.html
Roo
Andrew Low is offline
post #3 of 3 Old 06-02-2000, 11:29 AM - Thread Starter
paulh's Avatar
Cheers Mate!
paulh is offline
Closed Thread Screens
