Higher Gain Screens. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-07-2000, 07:38 PM - Thread Starter
jfaids's Avatar
I just got a E-home Marquee 8500, ceiling mounted, and I'm looking for a screen of moderate gain, 6.5 feet wide 16:9 aspect. I've seen a Stewart 1.5 gain screen and it looked great. I'm tempted to go with 2.0 gain Stewart (videomatte) or 1.8 gain "brilliant white" by Da-Lite. Are these higher gain screens good choices? The angle of view is ok by me, and the slightly enhanced brightess/immunity from ambient light would be welcomed. Would a 1.8-2.0 gain still be considered "modest"? I'm hoping to avoid severe hot-spotting, such as the 2.5 gain ML2500 Drapers. thanks.
jfaids is offline
post #2 of 3 Old 07-09-2000, 02:46 PM
Donald Bennett's Avatar
I wouldn't go any higher than a 1.8 gain.
I have a Stewart Videomatte 200 (gain 1.8) 87"W x 49"H screen and a Dwin HDP-500 with Faroudja DVP-2200. On flat fields there is a little hotspotting and on a menu screen with magenta rectangles (Like the AV Science forum screens) that go across the screen a little color shift can be seen in these bars. On normal video I get great performance and no noticable video artifacts.
Good Luck, Don
Donald Bennett is offline
post #3 of 3 Old 07-14-2000, 03:19 PM
Dean McManis's Avatar
I liked my Draper M2500 2.1 gain screen, but it did have some minor color shifting and hotspotting. It was the best looking high gain screen material that I had seen, but I only used it because I wanted a 10' wide screen, and I didn't want to overtax the projector.
But if you are going with a more reasonably sized 6.5 foot wide screen, the 8500 is easily bright enough to give you a good picture with a 1.5 gain screen without pushing the projector too hard, so I'd also recommend staying with the lower gain screen for the best picture quality at that size.
-Dean.
Dean McManis is offline
Closed Thread Screens
