Adjusting Dalite screen drop? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-27-2000, 04:09 AM - Thread Starter
dpearson's Avatar
I ordered (and have received) a dalite cosmopolitan tensioned electrol screen with the standard drop because the website said the limit switches were adjustable, now the manual says not to use these for "more or less" drop.
I've found a post here regarding wrinkling of dalite's tensioned screen if the down position is adjusted to less than the full drop.
Anyone else had this experience?
Rich/SrgtFury - Did you ever get resolution on this?
http://www.avsforum.com/ubb/Forum9/HTML/000146.html
-david
dpearson is offline
post #2 of 2 Old 07-27-2000, 07:28 PM - Thread Starter
dpearson's Avatar
I spoke with dalite today and all I could get from them was:
The limit switches are not for reducing drop. If you use them for this, it may affect the tensioning in the screen (eg. less tension). It will not damage the screen.
I guess I'll try it as soon as I can mount the screen and see what happens.
Thanks for your input.
dpearson is offline
Closed Thread Screens
