Sony VPH-1272q @ 100'' Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-28-2000, 08:04 AM - Thread Starter
AV8042's Avatar
I have a Sony VPH-1272q CRT Projector in my home theater which is
is a 14'x14' Room.I am going to go with a 100" screen(60x80).My
question is Which Screen.Ive been looking at the Da-lite perma-
wall With Cinema Vision Fabric and the Draper Cineperm With M1300 Fabric.Any suggestions would be greatly appreciated.One more question
While Setting up projector to painted wall I adjusted the color adj
that set up manual says never adj.Do I now need a tech to set this up?
Cant get color,white,scale right....I know,dumb move.
Alex
AV8042 is offline
post #2 of 3 Old 07-28-2000, 12:43 PM
Andrew Low's Avatar
I can't help with your tech questions -- but I can offer my opinion on screen material.
Both Draper and DaLite will send samples if you ask. Draper had an email address on their website that they accepted my request from, and DaLite had a 1-800 number.
I got a sample of both the M1300 and the CinemaVision. The CinemaVision had visible sparkles -- and I decided that as nearly invisible they were, I'd know they were there and opted for the M1300.
However, when my M1300 came it was _folded_ (sigh, apparently you can request it come rolled on a core). And the actual material that arrived is not 100% identical to the sample (but its still a great screen).
I'm using an 80" wide screen as well, but in a 16:9 aspect ratio.
So I've got no sparkles, but slight fold marks still.
Roo
Andrew Low is offline
post #3 of 3 Old 07-29-2000, 06:45 AM
JBJR's Avatar
Wow, I think i"d rather have the sparkles, than the folds. At a distance the you should not see any sparkley material(used for screen gain?), But the folds? Ouch!!
JBJR is offline
Closed Thread Screens
