Stretched canvas vs. blackout material - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-10-2000, 08:43 PM - Thread Starter
JamesC's Avatar
I've been reading as much as possible on all the choices for screens and would like to try a DIY one first. Has anyone done any comparisons of painted stretched canvas screens vs the ones made with blackout material?
JamesC is offline
post #2 of 3 Old 09-11-2000, 09:23 PM
kelliot's Avatar
My experience indicates the nonuniformities and grain on stretched canvas noticeable detracts from the viewing resolution. If you use canvas, you need to paint it to remove the non-uniformities, but the painting process tends to be non-uniform. Even said plain cotton duck canvas looks OK for starters.
Blackout material comes in different types and any given fabric store usually has a small selection. You have to decide what makes the most sense. I have seen white vinyl blackout that would look very good for a white matte screen and definitely better than canvas.
I was lucky to find a stretchable raincoat vinyl coated poly that makes a nice screen on the cloth side. The density of the weave is much better than canvas and barely noticeable. I like it the best because it is completely flat, extremely uniform and slightly grey so it has good color saturation.
Ken Elliott
Ken Elliott
kelliot is offline
post #3 of 3 Old 09-12-2000, 05:36 AM
Aslan's Avatar
Location: White Bear Lake, MN ----- CUSL2C, P3/1.0, 256Mb, HiPix, A2496, D50Q, Stewert 1.3g, Denon 3801,
Find a tailer that knows repair weaving. They can join two pieces together without a seam. I've had holes in suits fixed this way and without looking at the back you can't tell there was ever a problem.
Aslan...
Aslan is offline
Closed Thread Screens
