Is Stewart worth the extra $? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-10-2000, 03:11 PM - Thread Starter
Carl Hyslop's Avatar
It seems to me that Stewart are the king of screens. They certainly seem to be the most expensive brand, and all the reviewers have Stewart screens. Are they worth the extra $? By this I'm not asking about cost/benefit so much as - are they any better at all than cheaper screens?
Carl Hyslop is offline
post #2 of 7 Old 09-10-2000, 07:02 PM
Guy Kuo's Avatar
Yes, they do perform better than lesser screens. If one is within budget, a Stewert Studiotek 1.3 provides not only an excellent image, but piece of mind knowing that your screen is reference quality. You can select a lower cost screen, but be prepared for screen texture and sparkling artifacts which are absent on the Stewarts. It IS possible to be happy with another manufacturer, but if you can chose do it.
Guy Kuo
www.ovationsw.com
Ovation Software, the Home of AVIA DVD
Guy Kuo
Guy Kuo is offline
post #3 of 7 Old 09-11-2000, 02:32 PM
uncle eric's Avatar
Carl,
I entirely agree with Guy, this is my 4th and last screen. I wasted money for nothing. No more. Stewart, simply the best.
Eric
ISF, THX & HAA Certified
AV Talk Founder
uncle eric is offline
post #4 of 7 Old 09-11-2000, 07:17 PM
Jim Ferguson's Avatar
I've had my new Stewart Studiotek 130, 96x54" screen for just over a week now, and I couldn't be more pleased. The difference between this screen and my Da-Lite 1.3 gain screen is not subtle. It's night and day. The Stewart just disappears and lets the movie shine through. Its main attributes are that it is just perfectly neutral with no distractions.
  • No hot spot
  • No color shift
  • No streaks or screen grain
  • No awful "sparklies" like on the Da-Lite
Easily one of the most satisfying purchases I've ever made.
Jim Ferguson is offline
post #5 of 7 Old 09-12-2000, 06:34 PM
Daniel Hutnicki's Avatar
does Stewart make a manual screen?
Daniel Hutnicki is offline
post #6 of 7 Old 09-12-2000, 07:55 PM
kelliot's Avatar
I can make a good fabric screen using stretcher bars for about $60.00 that looks great.
Spend the money if you have it. I'd rather invest mine in a better projector.
Ken Elliott
Ken Elliott
kelliot is offline
post #7 of 7 Old 09-12-2000, 08:06 PM
Manual as in manual pull-down? I'm sure they do. Mine is a permanently-mounted fixed screen. Luckily it's a basement room, and there are no windows or anything else on that wall. Check Stewart's web site for more info.
Closed Thread Screens
