Cheap material for rear projection? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-13-2000, 05:01 AM - Thread Starter
telmnstr's Avatar
Hello.
I plan to migrate my barco into a trade show projector since it now
has a burn in mark center gun on all 3 guns.
I want to build a large portable box out of wood that can be put together into a large rear projection system.
Anyone have any suggestions for a really low cost material to use
as the front rear projection material? I figure the screen will be
about 6' high, and 20' wide. I plan to use a video projector in the middle with 3 slide projectors on each side, plus one slide projector in the middle to frame the video projector. Size is varible and I will have more of an idea on it once I get the slide projectors and a front surface mirror... and start to experiment.
Any and all suggestions are welcome.
telmnstr is offline
post #2 of 2 Old 09-13-2000, 11:45 AM
noah katz's Avatar
Quoted: 1107 Post(s)
Liked: 387
If you do a web search on "rear projection screens" you'll find a place or two that sells rear projection film material.
Noah
Noah
noah katz is offline
Closed Thread Screens
