Is 45" x 80" (16:9) too small of a screen for the Sony 400Q? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-18-2000, 12:26 PM - Thread Starter
Anthony Cler's Avatar
Quoted: 12 Post(s)
I'm in the process of planning my dedicated HT room and
will commence construction in the next month or two.
The projector I'll be using is the Sony 400Q and the room
dimensions will be approximately 15'W x 9'H x 22'L(subject
to change).
Viewing or seating distance will be around 13'.
I'm considering a smaller, but still high gain screen in
hopes that I'll get a higher quality picture.
I've also read multiple posts by 400Q owners who claim good
performance with much larger screens, but I've been watching
my 400Q(on a painted wall) from a seating distance of about
8 to 9' and an image size of about 5' wide for months now and
while I'm happy with the overall picture, scanlines are clearly
visible during fast vertical pans.
Am I better off with a smaller screen(45"T x 80"W), or would an
HTPC eliminate the scanlines on fast vertical pans, thus allowing
say a 106" diagonal screen?
Any and all input would be appreciated.
Anthony
Anthony Cler is offline
post #2 of 7 Old 09-18-2000, 08:58 PM
PAP
PAP's Avatar
If you are running w/o a doubler or scaler, then you will have image problems with nearly any size screen. That is your answer. The rest is all about lumens, and I don't know enough about the 400q to tell you that, but I ran my 8" crt barco at a 102" width screen but required 2.8 gain to do so adequately.
Good, cheap, easy - pick any two.
PAP is offline
post #3 of 7 Old 09-19-2000, 07:23 AM - Thread Starter
Quoted: 12 Post(s)
The 400Q puts out about 400 lumens and has a built-in line doubler.
The 400Q's built-in line doubler is acually pretty decent except during
fast vertical pans during which it falls back to interlaced video.
I plan to use a high gain screen regardless of the size. Probably around
2.0 to 2.5.
Anthony
It seems that most printed HT publications recommend smaller screen sizes, usually around 78" wide. At 45H x 80W my smallish screen would still be larger than what TJN at SGHT recommends.
Any other recommendations?
post #4 of 7 Old 09-19-2000, 08:40 AM
jthomas's Avatar
Anthony: I did have a Sony 400Q ceiling mounted and a 13' viewing distance to the first row of seats. I used a Stewart 16/9 1.8 gain screen after much experimentation with a painted wall and various screen samples. The size was 87" by 48/49" which with the little extra gain and on HDTV or DVD/HTPC I found the 13' viewing distance to be just right. I also noticed that for SDTV, I preferred the second row of seats. There was little, if any, shift in color or brightness from one side of the room to the other with the Stewart Screen. I would suggest that you are in the right size range, although many 400Q enthusiasts enjoy much larger screens.
J Thomas
J Thomas
jthomas is offline
post #5 of 7 Old 09-20-2000, 12:17 PM - Thread Starter
Quoted: 12 Post(s)
J Thomas,
Thanks for the reply.
So are you saying that when watching satalite TV that you preferred
a little more distance from that screen size? Or were you talking
about standard non-HTPC DVD?
Also, would you say that the HTPC made a significant improvement to
the 400Q? On a scale of 1 to 10, 10 being HDTV, where would you put
the 400Q's internal doubler vs. the HTPC's?
Anthony
post #6 of 7 Old 09-20-2000, 04:12 PM
sstieferman's Avatar
Ohhhh tough question. Here's my 400 outlook.
1. 3rd generation vhs copy.
3. late night ntsc
4. nice ntsc
7. excellent dvd
9. HTPC g400 most awesome, looking for an ntsc computer tv tuner that will work with it!!!!
10. my hdtv is provided by time warner cable, hbohd and showhd, take into consideration that TW is compressing the video feed. on excellent sourced 1080i during low cable modem usage, the picture is perfect in my book. I live in an apartment, so cable usage affects my hdtv.
i'm too scarred to see OTA or DSS HD...
hope this helps...
sstieferman is offline
post #7 of 7 Old 09-25-2000, 02:17 PM - Thread Starter
Quoted: 12 Post(s)
Thanks for the replies!
I'm really tempted to do the HTPC thing, I just want to be sure
that I'll see enough of improvement to warrant to cost.
From what I'm hearing here, it does.
So maybe I can go a little larger on the screen?
Closed Thread Screens
