Don Stewart: Screen Size Recommendations - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-22-2000, 12:15 PM - Thread Starter
BL
BL's Avatar
Don:
I have been using one of your competitors' fixed high-gain screens (approximately 2.3, I believe) which is 106" diagonal in a 16:9 configuration. I have a Sony 1272Q with 7" CRT's. I have complete control over light in the room. I am using a line doubler (the occasionally maligned IEV Turboscan T-1500, which I happen to like).
In most cases I am happy with my screen, but occasionally it has some mildly annoying qualities--streaks on the screen and some graininess. I am considering switching to one of your screens, but I don't want to reduce the screen size in any significant way. At the risk of asking a rhetorical question, I would like to know whether, in your view, would I still get an excellent and bright picture out of one of your 1.3 or 1.8 gain screens with 100" diagonal, or whether I would have to reduce my screen size. Are there other options? What do you normally recommend for people with 7" CRT front projectors like mine?
Any information you can give would be appreciated.
Thanks, Bill Leete
Bill
BL is offline
post #2 of 11 Old 09-22-2000, 04:52 PM
bryan_chow's Avatar
Hey, maybe we should ALL ask Don Stewart what size screen and what gain would be best for our projectors!
NOT!
Bryan
bryan_chow is offline
post #3 of 11 Old 09-24-2000, 07:36 PM - Thread Starter
BL
BL's Avatar
Bryan:
I don't think your post adds a lot. Yes, of course I am interested in my projector but please keep in mind the fact that the question of what screen size is appropriate for a certain size CRT is a subject that is frequently asked in this forum, and draws some strong opinions. Mr. Stewart is certainly in a position to provide a well-founded opinion on the subject.
In particular, I think that a lot of people in this forum have been using some frequently discussed high-gain screens that have some drawbacks. It follows then, that there may be some interest in finding out whether Mr. Stewart thinks that similar brightness and picture quality can be obtained from some of his screens that have a lower gain rating. There may also be some interest in learning whether he thinks that 7" CRTs can support a 100" screen.
The bottom line is that he is free to answer or not. So far he hasn't, and he may not, but that does not mean the post was inappropriate.
Bill Leete
[This message has been edited by BL (edited 09-24-2000).]
Bill
BL is offline
post #4 of 11 Old 09-24-2000, 09:08 PM
Steve Bruzonsky's Avatar
Quoted: 439 Post(s)
Liked: 101
I think that Don may take weekends off from work to be with his family.
How do you like that?
Steve Bruzonsky
You mean you don't remember me? Back 1999 - 2003, I started and moderated the AVS Tweaks forum and also the AVS Special Guests forum.
My home theater at:
http://www.avsforum.com/avs-vb/showthread.php?t=1158431
Steve Bruzonsky is online now
post #5 of 11 Old 09-24-2000, 09:17 PM
Forrest's Avatar
Hey Bill-
I am actually in the "same boat" as you. I have a Sony D50 (7" CRT's) and a Draper M2500. It sounds like you also have an M2500 from your description of it. I like the picture on the M2500, but I can't live with those annoying streaks. I just received a sample of the Stewart Ultramatte 200. It looks a little darker than the Draper (it should it has less gain). I think I am going to buy the Ultramatte in 89"X48", but I am on the fence trying to decide. I currently have an 84"X45" screen and I am concerned about brightness levels. It is hard to decide. Good luck in your quest, I am trying to decide for myself this week. Have you ever seen the Vutek 3.1 by any chance? Forrest.
Forrest is offline
post #6 of 11 Old 09-24-2000, 09:18 PM
Forrest's Avatar
Hey Bill-
Forrest is offline
post #7 of 11 Old 09-25-2000, 02:32 PM
Don Stewart's Avatar
Quoted: 97 Post(s)
Liked: 87
Dear BL,
Sorry I took so long to respond but quit frankly... my typing skills suck, so its takes me a little time to answer technical questions. Sorry that you took some heat from some other postings. I did post a formula " How to predict screen brightness with intent to give you and others the information you were seeking.
These are the foot Lambert numbers that I come up with on a 100" 16x9 screen with your current project. Your numbers will not be as good if your CRTs' have thousands of hours clocked on them.
Gain---------------Ft. lamberts.
1--------------------6.08
1.3------------------7.9
1.8------------------10.94
2.0------------------12.16
2.3------------------13.98
2.5------------------15.2
The numbers on the gain screens would be in the center of the theater and your projector would have to be ceiling mounted to take full advantage of the gain surface.
Don
Don Stewart
Manufactures of Precision Professional Projection Screens.
http://www.stewartfilmscreen.com/
Don Stewart is offline
post #8 of 11 Old 09-25-2000, 02:48 PM
Quoted: 97 Post(s)
Liked: 87
I told you my typing was bad..
On the above posting change "quit" to quite and "project" to projector. I can spell...I just can't type....Sorry about that.
Don Stewart
post #9 of 11 Old 09-25-2000, 03:58 PM - Thread Starter
BL
BL's Avatar
Don:
Thanks for answering my post! I assume that the figures you supply are based on the manufacturer's recommended distance for the particular screen size.
I have a couple of follow-up questions: First, I assume that brighter is better, but is there a particular target foot-lambert level that you like to see or shoot for using 7" CRTs? Second, do your figures assume at least line doubling, or do the measurements not indicate a significant difference in brightness between a doubled and non-doubled image?
Bill Leete
Bill
BL is offline
post #10 of 11 Old 09-25-2000, 07:03 PM
Tim Wilkins's Avatar
BL, brightness and line doubling is a misconception, see my posting in the thread below. I believed it too at one time.
http://www.avsforum.com/ubb/Forum2/HTML/003221.html
Further explanation in this presentation:
http://dtvconsultants.com/sld026.htm
[This message has been edited by Tim Wilkins (edited 09-25-2000).]
Tim Wilkins is offline
post #11 of 11 Old 09-25-2000, 10:52 PM - Thread Starter
BL
BL's Avatar
Forrest:
You are correct in your conclusions, it would be nice to have life without streaks, but I hate to give up the brightness. I will be interested to see how you like the new screen. I have not seen the Vutec--unfortunately, one of the drawbacks to living in Maine is virtually no one has a front projector and I know of only one store with one on display (it is a Vidikron). I am thinking about scheduling a trip to Boston to see some other screens, but that won't be for a while.
Steve:
You are absolutely right!
Bill
[This message has been edited by BL (edited 09-25-2000).]
Bill
BL is offline
Closed Thread Screens
