AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Screens (http://www.avsforum.com/forum/23-screens/)
-   -   Stupid Crazy "grey screen" idea for LCD's (http://www.avsforum.com/forum/23-screens/19181-stupid-crazy-grey-screen-idea-lcd-s.html)
lawdawg 10-19-2000 11:41 AM
Okay, this is probably dumb, and I'm sure you will all tell me about it, but....What are the odds that placing a grey filter over/in front of the projector lens will work to give increased black level perception? Like a 5% percent grey film or something greater/lower maybe? It would cut down on the light output, but a sufficently powerfull projector could compensate for this, yes?
Adam Litchy
noah katz 10-19-2000 04:47 PM
No problem, it's already been done. However, it doesn't do anything to reduce the effect of ambient light on the screen, whereas a gray screen will.
Noah
lawdawg 10-19-2000 06:32 PM
Noah,
So does this mean it actually has a postive effect on black level without screwing up the rest of the image? Ambient light is not a consideration in my environment. So if that is the only downside, I should be cool.
Adam Litchy
noah katz 10-19-2000 09:08 PM
Adam,
Yes, it's the same as if the bulb itself were putting out less light (but still the same color).
Noah
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
