AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Screens (http://www.avsforum.com/forum/23-screens/)
-   -   Is it possible to order just the material from Dalite (http://www.avsforum.com/forum/23-screens/19183-possible-order-just-material-dalite.html)
Jerry 10-20-2000 04:33 AM
Hi,
I've got a Dalite Electrol screen (mat white) and am considering replacing it with the 1.5 gain video screen. Is it possible to order just the material and replace it myself or would I be better off selling this one and buying another?
Thanks, Jerry
Jeffrey 10-20-2000 06:21 AM
Hi Jerry
It is possible to order just the screen material. Dalite representatives are very helpful, on the phone. A dealer will have to order it for you. I think AVS is a Dalite dealer, even though the products are not on their web site.
Jeff
Paul K 10-20-2000 08:17 AM
It is not only possible, but recommended by me. I did just that and was able to get the exact type of screen in the exact size I wanted. By ordering fabric with grommetts around the perimeter, I was able to create a screen that is tight, like a drum, and thus super flat and wrinkle free. See my construction pics here
http://sites.netscape.net/kr0n0s/htpics
wireburn 10-20-2000 12:08 PM
It is interesting to note that Dalite charges more (actually MUCH more) for the material alone than when installed in a screen. For instance, I got a quote for Hi Power material in 92x52 for four-hundred-something dollars. I can buy the same screen in a Model B for just $255 shipped.
I have also heard, but can't confirm, that the rolls used on the model B are interchangeable with the ones used on the Cosmo Electrols. This means that you could replace your Electrol screen material with a roll from a model B for about half what it would cost to purchase the replacement material alone.
-Mike
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
