AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Screens (http://www.avsforum.com/forum/23-screens/)
-   -   DIY masking panels for FP screen (http://www.avsforum.com/forum/23-screens/19192-diy-masking-panels-fp-screen.html)
DMan 10-25-2000 09:18 PM
I am using a 1.85:1 Draper M2500 (52"x96") screen and I would like to add some masking panels at the top and bottom of my screen to mask the aspect ratio for 2.35:1 DVD movies. I would like to build these panels to be hinged so that I may swing these into place when needed and swing them away from the screen when not in use.
My question is, does anyone have any ideas concerning materials and construction ideas/techniques or even better does someone have pics of similar masking panels that have been built by any DIYers? I would love to have a professional masking system by Draper or Stewart, but the budget simply won't allow for it.
As always, I appreciate any and all responses. http://www.avsforum.com/ubb/smile.gif
DMan
The Academy Home Theater
[This message has been edited by DMan (edited 10-26-2000).]
kevinu 10-27-2000 01:09 PM
DMAN,
I would also like the Stewart masking screen. Since budget won't allow it, I made my own.
I went to a print shop and bought a 3/4 thick by 4 by 8 sheet of black gator board. It is a foam core with black paper adhered to each side. I ripped four pieces. Two for 185, two for 235.
I crosscut them to fit snuggly inside the frame. The stuuf is so light it will stay. If it did not stay I would have used velcro for the top piece. Works great. I paid $60 for the sheet.
It cuts like wood. I used my table saw to rip, power miter saw to crosscut.
Good luck, Kevin
wireburn 10-28-2000 05:10 AM
I have heard of using magnets to attach lighter masking materials to the screen. This scenario would work well for pulldown/electric screens, too.
-Mike
kevinu 10-28-2000 09:57 AM
Larry,
It is quite easy to change sizes of masking. The foamboard wedges snuggly between the vertical frame in front of the screen.
I have a Stewart 4by3 84 diagonal screen with 1 1/2 inch frame.
Kevin
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
