Seating Distance - Your preference? - AVS Forum | Home Theater Discussions And Reviews
Old 11-03-2000, 12:57 PM - Thread Starter
arrow's Avatar
In one of Blake's messages, he recommends 3 times the height of the screen as the viewing distance.
Out of curiosity, what do you find is your viewing preference?
--Les
arrow is offline
Old 11-03-2000, 02:44 PM
Andrew Low's Avatar
I like to sit with my head about 11feet from my 80inch wide 16:9 screen.
Yup, its big.
Roo
Andrew Low is offline
Old 11-03-2000, 08:22 PM
steve5097's Avatar
I like about 3 screen heights for DVD watching. For cable TV stations, depending on the quality of the station, I usually zoom it down to 4+ screen heights because the lack of resolution is noticeable. If I had satelite or digital cable, I'd probably zoom it back up.
Steve
Steve
steve5097 is offline
Old 11-03-2000, 11:21 PM - Thread Starter
arrow's Avatar
For those playing at home...
An 80 inch wide 16:9 screen is 45 inches in height. Mr Low sits 11 feet away which is 3 times his screen's height.
What a lemming ;-)
--Les
arrow is offline
Old 11-06-2000, 08:19 AM
Andrew Low's Avatar
Hey, I can't do math.. http://www.avsforum.com/ubb/smile.gif
Old 11-08-2000, 02:14 PM
Dean McManis's Avatar
I sit 15' away from a 13' wide screen. Or 2X screen height.
The picture is a bit soft for NTSC sources, but 90% of my viewing is movies, and DVDs scaled with a HTPC to 1365 X 1024p, and HD scaled to the same resolution look excellent at that distance/size to me.
-Dean.
[This message has been edited by Dean McManis (edited 11-08-2000).]
Dean McManis is offline
