AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Screens (http://www.avsforum.com/forum/23-screens/)
-   -   Swinging up a fixed screen - any problems? (http://www.avsforum.com/forum/23-screens/19229-swinging-up-fixed-screen-any-problems.html)
Dennis Nicholls 11-25-2000 12:50 PM
I never am one to listen to good advice. I was told that a roll-up screen would give poor results in a HT but went ahead and bought one anyway. I got a 1.5 gain Da-Lite model "C", and while it doesn't look bad and is built well, the lack of flatness is more apparent than I thought.
My problem is my room. The only place to put the screen is in front of the patio doors, so it has to be moved out of the way when not watching movies.
I am considering getting a Draper M2500 58" by 79" screens, hanging it in the proper place, and then swinging it up when not in use. The shipping weight is 27 pounds so I assume the net weight is about 22 pounds. I would mount some kind of attachment to the ceiling so that the screen would be parallel to the ceiling but high enough to walk under. (Note: I have an Electrohome single-lens ECP graphics so I have considered well both the color-shift and aspect ratio issues.)
Has anyone tried this? Are the Draper screens too fragile to handle daily moving?
kelliot 11-25-2000 02:27 PM
DIY screens can be much lighter.
Also, if one uses stretcher bars, hinges and springs should be pretty simple to implement.
Ken Elliott
Emil Naepflein 11-26-2000 12:34 AM
Hi,
you should have bought a tensioned screen. I know these are much more expensive, but IMHO the absolute flat surface is worth the extra money.
I am owner of a Da-Lite Tensioned Cosmopolitan.
Emil
Bill Lucas 11-26-2000 07:10 AM
Dennis,
I'll be glad to actually address your question. http://www.avsforum.com/ubb/smile.gif
I have a 92" X 52" fixed screen and I've done exactly what you've asked. My screen probably weighs about 35lbs. and I have seen no signs of a problem. A friend in this area has also used this method for 1 1/2 years with no problems. It would be best if you can set it up so that you are lagging into the joists above (as opposed to drywall). Mine is mounted to the wall at the top and swings up to connect to hooks that are lagged into floor joists. Hope this helps.
Jeff Smith 11-26-2000 11:14 AM
I also have a screen that swings up to the ceiling. I used a Dalite screen called the "wraparound". In this screen, the viewing serface comes all away to the edge of the frame, there is no border at all. What this allows, since I have my screen mounted some one to two feet off the wall (it sits at an angle) is for the image to appear to be floating in midair. Any over scan, or spillage of light, is only seen on a brick wall far in the background. In effect it is completely unnoticeable, less noticeable in fact, then the excess light on the black border of my standard screen that I used prior to this one. As mentioned in other posts, my screen is also extremely lightweight, perfectly flat, and I made a custom-made box on the ceiling out of nicely stained 2 by 4's which keeps dust out when folded up. I custom-made my own hinge mechanism, but it was extremely easy. I'm surprised more people don't use this method. I personally do not like the black borders, and in my application and room the black borders added unacceptable width to the screen that made it hard get my speakers where I wanted them.
Good luck
Jeff
Jeff Smith
[This message has been edited by Jeff Smith (edited 11-26-2000).]
Carey P 11-26-2000 09:36 PM
Dennis,
Just to comment on your choice of screen. I have the exact 4:3 size you are looking for in the M2500. It's a tab-tensioned Premier electric screen from Draper. It stays perfectly flat always, and easily hangs from the ceiling with 2 S-hooks (it's heavy so joists are recommended), or mounts into the corner against the wall. I've used it both ways.
The problem is, after a while, the structure of the screen started to bother me (you can see certain areas of the screen in bright scenes). This, coupled with the fact that I wanted to go to 16:9 at 96" width, I've temporarily set up a simple "black-out cloth" which works surprisingly well.
I don't know if the newer M2500 material is any different (I bought mine over 3 years ago). There are threads on this particular subject elsewhere. Just wanted you to be aware of this issue. Otherwise, it does provide good brightness and better contrast than a flat gain screen (which I miss). If you are really settled on this screen, I'm wanting to sell mine, though I can't imagine how one would ship the thing. I don't have the original box. You can email me if want.
Carey
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
