Did I order the wrong screen? - AVS | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By IanR
post #1 of 7 Old 03-07-2015, 09:31 AM - Thread Starter
Liked: 0
Question Did I order the wrong screen?
Hi,
I'm building a theater room in my house for the first time and I'm not sure if I made a mistake with my screen. Nothing is hooked up or mounted yet.
My projector is Sony VPL-HW40ES. It'll be approx 17 feet away from the screen. The room will be completely dark.
I meant to order the Draper Onyx Matt White XT1000V (1 gain) but instead ordered Pure White XT1300V (1.3 gain).
Is this going to make a difference in picture quality or color? Will I regret this?
Carl1979 is offline
post #2 of 7 Old 03-08-2015, 06:33 PM
old corps's Avatar
Quoted: 104 Post(s)
Liked: 59
Originally Posted by Carl1979 View Post
Hi,
I'm betting it'll be fine but it'd be nice to know what size screen you're talking about. You can always find ways to tone down brightness but if the pic isn't bright enough not much you can do. Also, the lamp starts getting dimmer from the 1st time you use the pj, not brighter. JMHO
Ed
old corps is online now
post #3 of 7 Old 03-08-2015, 06:46 PM
IanR's Avatar
Quoted: 34 Post(s)
Liked: 26
I have an HW40ES as well .. projecting from about 14' onto a DIY painted 105" diagonal screen with a gain of about 1.3 according to the guys who came up with paint mixture. I was concerned about the higher gain as well but it works fine even on ECO (low-light) mode. I don't know anything about the quality of that specific screen but if you're concerned about the gain, I don't think you need to be. And as Old Corps said, the bulb will dim over time and if you have a larger screen and watch a lot of 3D, you'll appreciate the higher gain.
old corps likes this.
Ian
My finished "Media Room"
IanR is offline
post #4 of 7 Old 03-10-2015, 08:39 AM
Schlemstar's Avatar
Quoted: 18 Post(s)
I have the same projector using a SeymourAV Glacier White non-AT 1.3 gain screen at a throw distance of 16.9 feet. I run the pj in eco mode all the time (except for 3D) and the picture is exceptional!
Schlemstar is offline
post #5 of 7 Old 03-16-2015, 06:12 PM - Thread Starter
Liked: 0
It's a 120" diagonal screen.
Ed
Carl1979 is offline
post #6 of 7 Old 03-16-2015, 06:13 PM - Thread Starter
Liked: 0
Thanks for the info guys, it definitely helps. I guess I don't need to be too concerned
Carl1979 is offline
post #7 of 7 Unread Today, 02:03 PM
WildWolf's Avatar
Do you still get good black levels and depth with a 1.3 gain on that Sony projector?
WildWolf is online now
Reply Screens
