Walls as screens - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-01-2000, 01:53 PM - Thread Starter
dcottle's Avatar
This idea of a DIY screen sounds interesting. I would like to try the quick and cheap option of turning an area of a wall into a screen. The wall is drywall that is painted with an off-white (the paint probably contains small amounts of yellow and red) with a satin finish.
I would use a flat, ultrapure white paint as suggested in this forum for other DIY screens.
1. Do I need to sand the surface smooth?
2. How many coats of paint should be necessary?
3. I am not expecting to need to use a primer. Is this a valid assumption?
4. What type of roller would be best?
5. There will be a lot of ambient light at times. What can I do to minimize the effects of the light?
Dave
dcottle is offline
post #2 of 3 Old 12-02-2000, 02:09 PM
paul_mullen's Avatar
Dave,
I did just what are talking about this past week. My wall was a kind of tan color. I filled a couple of imperfections with drywall compound and sanded the whole area very lightly. I used 3 coats of Flat Behr Ultra Pure White paint. I have heard of others using eggshell which is one step up in sheen from flat. This gives the screen some gain. I can get my room completey dark so I went with the flat. I used a Purdy 1/4" nap roller and this left a very smooth finish. Just take your time and roll slowly and thoroughly smooth out all the paint. It came out great.
Good Luck!
Paul
paul_mullen is offline
post #3 of 3 Old 12-03-2000, 01:03 PM
MrWigggles's Avatar
Dave,
I agree completely with Paul.
You can also use floetrol to help keep things smooth. I also do recommend the eggshell but I didn't have very good results with the satin level. Things started to hotspot.
Also texturing on your walls (if applicable) will screw things up. Sand it smooth.
-Mr. Wigggles
Ps. Stewart recomended homemade screens himself for unity gain on the Big Picture's VW10HT forum.
The Mothership is now boarding.
MrWigggles is offline
Closed Thread Screens
