Distance From Screen - AVS Forum | Home Theater Discussions And Reviews
Old 12-21-2000, 12:42 PM - Thread Starter
Sore Eyes's Avatar
I know that the proper distance to sit from a screen is subjective, but if I normally sit one half to two thirds back from the screen in a standard theater, how far back should I sit from an 11 foot wide (16:9) screen for approximately the same experience? (I am designing a theater and picking a screen size.)
Sore Eyes is offline
Old 12-23-2000, 07:05 PM
LeeAntin's Avatar
The rule of thumb is between 2 and 3 times the picture height. This assumes some line doubling, scaling or HDTV. Normal NTSC is 5 times picture height so the scan lines will disappear.
Lee
LeeAntin is offline
Old 12-23-2000, 10:06 PM
Phil Olson's Avatar
I read somewhere, (THX I think), that the ideal is a minimum of 30 degree field of vision, preferably 45 degrees. That being said, if you can get a good idea of what your field of view is in the theater, try to make your screen at home encompase the same view.
Next time you're there, place your hands verticaly against your face and slide your hands together till the sides of the screen are just visible, and remember exactly where your hands are. Then go home and place your hands in the same place.
At that point, you can sit at a fixed position and adjust what screen size you want, or with a fixed screen adjust how far back you sit to get the screen edges to just appear.
Personally, I sit 1/3 to 1/2 way back from the front.
Phil
Phil Olson is offline
Old 12-23-2000, 10:09 PM - Thread Starter
Sore Eyes's Avatar
Thanks Phil
