Da-Lite screen for NEC CRT? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-27-2000, 02:02 AM - Thread Starter
Norman's Avatar
Hi all,
Marry Christmas for all!
Is the Da-Lite 52"x92" screen (Model B Matt white) good for NEC XG135LC?
"Most important thing is information!"
Norman
Norman
Norman is offline
post #2 of 3 Old 12-27-2000, 02:07 AM
Bill Lucas's Avatar
No. I have yet to see a Model B screen that does not have waves in it. These waves results in an uneven image and can ruin the viewing experience. That's a great projector. Don't go cheap on the screen. It won't pay off. Spend a few hudred more and get a fixed screen that is perfectly flat. If the screen must drop down then you'll be looking at tab-tensioned screens and those can get darned expensive. Regards.
Bill Lucas is offline
post #3 of 3 Old 12-27-2000, 02:12 AM - Thread Starter
Norman's Avatar
Thanks Bill,
But which screen you suggest?
Norman
Norman
Norman is offline
Closed Thread Screens
