Full Masking System - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-29-2000, 01:09 PM - Thread Starter
Sore Eyes's Avatar
I don't want to build my own masking system for an 11 ft. wide, 16:9 screen. Does anyone build a system that allows for both top/bottom AND sides to be adjusted by masks?
Sore Eyes is offline
post #2 of 7 Old 12-29-2000, 03:05 PM
Dean McManis's Avatar
Sore Eyes,
I made my own masking system for my 13' wide screen, but it was a project to design/build and currently is manually operated.
I'm sure that someone would be willing to design a custom masking system for larger screen sizes like ours, but it won't be cheap.
-Dean.
Dean McManis is offline
post #3 of 7 Old 12-30-2000, 09:25 PM
CHUCK GIGLIO's Avatar
stewart makes them, i called and got a price of $4500. for a 110" screen.
so i made my own.
chuck
CHUCK GIGLIO is offline
post #4 of 7 Old 12-30-2000, 09:39 PM - Thread Starter
Sore Eyes's Avatar
Thanks Chuck,
I thought Stewart only made side drop masks.
post #5 of 7 Old 12-31-2000, 10:14 AM
Steve Bruzonsky's Avatar
Quoted: 635 Post(s)
Liked: 201
Stewart does make its 4 way masking system, which I have, which includes adjustable masks top and bottom, and side masks which drop from the top to mask the 16:9 screen to 4:3. However, Stewart can custom make a screen with side panels which mask from side to side adjustably, but at a higher custom cost. You should e-mail or private message forum member Don Stewart about this and he can fill you in.
Steve Bruzonsky
You mean you don't remember me? Back 1999 - 2003, I started and moderated the AVS Tweaks forum and also the AVS Special Guests forum.
My home theater at:
http://www.avsforum.com/avs-vb/showthread.php?t=1158431
Steve Bruzonsky is online now
post #6 of 7 Old 12-31-2000, 10:19 AM - Thread Starter
Sore Eyes's Avatar
Thanks Steve, I'll do that.
By the way, what projector do you use and how far back do you sit from a 13 foot screen?
post #7 of 7 Old 12-31-2000, 12:40 PM
Sore Eyes,
My main seating is 15' away from my 13' screen with some closer seating at 8' away. At this distance the picture is a little soft with VHS, LD, DSS material, but looks great with scaled DVDs and HD movies.
-Dean.
Closed Thread Screens
