DIY Screen Frame - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-04-2001, 04:07 AM - Thread Starter
pcdoctor's Avatar
Has anyone painted their DIY screen frame using flat black paint or are you using black felt?
Which are you using and why?
pcdoctor is offline
post #2 of 3 Old 01-04-2001, 07:58 AM
sstieferman's Avatar
<font face="Verdana, Arial" size="2">Originally posted by pcdoctor:
</font>
Check out http://www.geocities.com/sstieferman
I chose a dark stain and am very pleased with it. Personally, if I were to do it again - I would wrap the frame in a black velvet first and then mount the screen to it.
I would not suggest paint because of possible flaking - you know - black dandruff! As for the felt, Velvet has a tighter weave and backing material over felt. When I've worked with felt in the past, it is see through when light reflects off of the material below it.
sstieferman is offline
post #3 of 3 Old 01-04-2001, 09:17 AM - Thread Starter
pcdoctor's Avatar
Thank you so much!
I appreciate the info.
Glenise
pcdoctor is offline
Closed Thread Screens
