AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Screens (http://www.avsforum.com/forum/23-screens/)
-   -   screen/wrinkles (http://www.avsforum.com/forum/23-screens/19329-screen-wrinkles.html)
kenh 01-12-2001 07:06 AM
I went out last night and bought some blackout material (Joan fabrics)and it is loaded with wrinkles and so forth any suggestions and how to get them out? I have it hanging now and plan on making a frame but I do not think this will get out all of the wrinkles, this is all they had in stock. they suggested putting it in the dryer (low temp.) for a while. also I have it over a window and some light still gets through. thanks.
pcdoctor 01-12-2001 11:29 PM
I have purchased the curtain blackout material also and was wondering the same thing.
It will be a while before I put my screen up though.
Have you figured out a way to remove wrinkles?
My HT
Frank J Manrique 01-12-2001 11:54 PM
Can steam irons--like drapery installers use--be of help?
Just an idea...
-THTS
kenh 01-14-2001 08:23 AM
The ladie from Joann's suggested putting the material in the dryer with a damp towel and dry a low temp. for 5 minutes. I tried this and it got a huge amount of the wrinkles out. I also rolled the material up on a cardboard roll right out of the dryer that i got from Joann's
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
