can you make your own grey screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-22-2001, 05:04 PM - Thread Starter
rlsmith's Avatar
Several posts have referred to making your own grey screen for use with a DLP (or similar) projector.
Does anyone know how you would go about making your own grey screen?
Bob Smith
rlsmith is offline
post #2 of 6 Old 01-22-2001, 07:29 PM
Don Stewart's Avatar
Quoted: 73 Post(s)
Liked: 74
Search for some postings by KBK. He has some formulated gray screen paint that may be just what you are looking for.
Don
Don Stewart
Manufactures of Precision Professional Projection Screens.
http://www.stewartfilmscreen.com/
Don Stewart is offline
post #3 of 6 Old 01-23-2001, 08:15 AM
bwolff's Avatar
I dyed a king sized sheet and it works good. I am working on a strait wall right now and I am going to paint it.
~~~~~~~~Bwolff~~~~~~~~
Champagne tastes with a beer budget
My Theater
bwolff is offline
post #4 of 6 Old 01-23-2001, 01:11 PM
CCLAY's Avatar
Bob,
If you want a very simple to do screen, go buy a 4 x 8 piece of masonite. One side is perforated, one side is smooth, your choice.
Attach to your wall using mirror supports, available at hardware stores. Buy a gallon of pastel base white and an oz or two of lamp black colorant, then mix to a very light shade of grey. Be careful, a little black goes a long way. I suggest using a quart jar rather than mixing in the whole gallon.
Using the paint method gives you GREAT flexibility for trying different shades of grey to best suit your needs.
E-mail me if you want more info.
Chris
My Home Theater is a work in progress.
CCLAY is offline
post #5 of 6 Old 01-23-2001, 09:04 PM
mdowns's Avatar
Bob,
I followed Bwolff's research posts and my variation has worked well for me. I wanted to try my hand a DIY custom sized screen before I threw down cash for a REAL screen. After putting together my frame, I went to Wal-Mart and purchased two King sized flat sheets. They were cheap and disposable if this project didn't work out. I placed a 180 thread count black sheet over the frame and stapled in place. Over the black sheet, I placed a 200 count white sheet, made by Cannon, and again stapled in place. The black backed sheet seems to give the white sheet a grayish tint that makes the blacks blacker and doesn't really effect the whites that much. Applying two layers of white makes the whites whiter, but the blacks now have a grayish look. My total cost was about $50. I finished out the screen with black felt wrapped 2" foam border. The screen is light enough that you can hold the 60" X 104" screen in one hand. This will satisfy me until something strikingly different comes along. BTW, I'm using the Sony W400Q projector at a distance of 14.5 feet. Good luck. MD
mdowns is offline
post #6 of 6 Old 01-24-2001, 06:30 AM
bwolff's Avatar
I tried the masonite. First it is too small for me and second it had hotspoting. But I have a LCD. They sell poster board in 4x8 sheets. That is a little more but it is light and flat.
My Theater
bwolff is offline
Closed Thread Screens
