AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Screens (http://www.avsforum.com/forum/23-screens/)
-   -   Stewart Screen - Screen Trigger Interface (http://www.avsforum.com/forum/23-screens/19357-stewart-screen-screen-trigger-interface.html)
Jose Alvarez 01-24-2001 08:27 AM
I am thinking of buy a Stewart Luxus Model A Electriscreen with the screen trigger Interface. I contacted Stewart and they faxed me the wiring diagram. The diagram shows a 2-conductor hook-up cable , 22ga minimum (not supplied). Does anyone know where I can get that cable (10' to 15' long)? Does anyone know the size of the plugs that screen transformer takes ( 3.5 mm mini mono ,1/4" plugs, etc.). I am planning to buy the DWIN Transvision DLP projector. The cable will be connected to one of the two 12v screen outputs in the video controller. Does anyone the size of the plug that the video controller takes. Can anyboby help me?
Jeffrey 01-24-2001 08:38 AM
Hi Jose
I don't know what type of plugs/connections are necessary, but I'll take a shot at the wire. I suggest using regular "thermostat" wire. It is 18-20 ga. and available at any home store. It is rated to be pulled in-wall. It is also very inexpensive.
Catagory 5 or the like is 24 ga., which is not as heavy as the specified wire.
Good luck
Jeff Streitz
Iowa City, IA
(the guy that bought your 2-pairs of BIC in-walls)
DMan 01-24-2001 07:24 PM
Don,
I just purchased a Stewart Horizontal Screenwall Electrimask Model and the unit comes with 2 High Voltage Wall switches for the masking panels. Can I purchase an IR controller unit at a later date and add it on, or is this something that has to be ordered with the screen and cannot be changed at a later date?
Thank you,
DMan
The Academy Home Theater
Don Stewart 01-24-2001 07:54 PM
Originally posted by DMan:
Don,
Thank you,
DMan,
You can add it at anytime.
The unit that you ordered has two motors, one for the top masking and one for the bottom masking. The basic unit comes standard with high voltage switching. For IR control we add an outboard low voltage circuit for each motor. The low voltage motor switching boxes have an IR port and can be ordered with with a hand control or the codes can be programmed into a master IR control system. You can wire the motors pigtails into the boxes terminal strips with a screwdriver in 5 minutes or less. Its an easy add on.
Don
Steve Bruzonsky 01-24-2001 09:04 PM
DMan, you are gonna just luuvvvvvvvvvvvvv your new screen!
As I luvvvvvv my Electrimask Stewart screen, too. The screen is the only part of my totally wired home theater that my wife likes!!!
Steve Bruzonsky
Don Stewart 01-24-2001 09:05 PM
Almost any type of 2 strand wire will work here. The trigger's relay coil requires only 3.5 Ma. The screen trigger comes with two 3.5mm/ 1/8'' mono plugs so you can make a cable on sight. Most projectors use this connector as well.
Don
DMan 01-24-2001 10:53 PM
Don,
Thank you very much for the info.! I can't wait for this screen to get here! Your screens are second to none, and it took me finally seeing one to see what all the fuss was about. Thanks again!
Steve,
You played a very vital role in my decision with your wonderful descriptions of your new Stewart screen. I really appreciate all your help and information.
Thanks again,
DMan
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
