Sherwin Williams Luminous White - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-29-2001, 04:03 PM - Thread Starter
JasonBrooks's Avatar
I am building my screen and have read that many of you use this paint. What gloss do you get? My local SW store sells it in flat satin and semi gloss.
Signature...Does anyone have a pen I can borrow?
JasonBrooks is offline
post #2 of 3 Old 01-29-2001, 04:35 PM
KBK
KBK's Avatar
I would immediately suggest the flat satin finish. You might try a bit of each if it is cheap enough, to arrive at a slightly higher gain mixture than the flat satin alone. I feel that the semi-gloss will be too hot (higer gain, but with too much hot-spotting) to be useful. I have never used either, but I am familiar with finishing texture characteristics.
Two coats will probably work better than one.
---Place Signature Here---
Ken Hotte
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge.
KBK is offline
post #3 of 3 Old 01-29-2001, 04:47 PM - Thread Starter
Whoops! I did not mean flat satin and semi gloss. I meant flat, satin, or semi gloss. KBK would you suggest the flat or the satin?
Closed Thread Screens
