Help me decide on Inexpensive LCD screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-31-2001, 06:22 PM - Thread Starter
wingryder's Avatar
I have a Sharp XVP10U LCD projector. It will be
mounted eye level about 13 feet from screen.
Which is these pull down screens would be best?. I am using a
JoAnn Blackout now and its good but too dark. (room is dark)
Dalite- matte white, Video Spectre, Glass Bead or High Power
Draper- matte white, glass bead, or F1500. DVD Movies only.
thanks for your input.
don
wingryder is offline
post #2 of 4 Old 02-01-2001, 02:42 AM
pcdoctor's Avatar
If you go with a dalite model b pull down, make sure you get the high power because wrinkles don't show.
My HT
pcdoctor is offline
post #3 of 4 Old 02-01-2001, 05:41 PM
Jordan's Avatar
Ditto on the HiPower & wrinkles - it reduces the effects. It won't eliminate them, though. It does work in ceiling mount configs, contrary to DaLite's own advice. It just ends up like a 1.4-1.6 gain screen instead of a 2.5-2.8. I have one for my 10HT and it is quite nice. Just look out, 'cause on-axis (max gain) the picture looks a tad grainy.
Jordan
Jordan is offline
post #4 of 4 Old 02-03-2001, 02:01 PM - Thread Starter
wingryder's Avatar
Thanks to both on the replies so far. I have contacted several
manufactures and now waiting for samples to arrive.
Any other tricks to increase brightness? Like shadow boxes?
(no, cant make a projector change right now)
Closed Thread Screens
