1.78 vs 1.85? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-07-2001, 11:14 AM - Thread Starter
Steve Bruzonsky's Avatar
Quoted: 439 Post(s)
Liked: 100
Widescreen DVDs are mostly 1.85 or wider, like 2.35.
But HDTV is 1:78.
So I recommend a 1:78 screen, and if you can afford it, masking at top and bottom for other aspect ratios, from 1.85 to 2.35 and even beyond. I luv my Stewart 4 Way Electrimask, and D-Man just ordered a Stewart Electrimask with masking only at the top and bottom.
Steve Bruzonsky
You mean you don't remember me? Back 1999 - 2003, I started and moderated the AVS Tweaks forum and also the AVS Special Guests forum.
My home theater at:
http://www.avsforum.com/avs-vb/showthread.php?t=1158431
Steve Bruzonsky is offline
post #2 of 8 Old 02-07-2001, 02:33 PM
mflaster's Avatar
I had the exact same question. But let's say you don't plan on any masking system. Does it really matter if the black bars are on the top or the side? It seems that if you plan on watching more 1.85 DVD's than HDTV, you should get a 1.85 screen. Many DVD's are 1.85, and there's currently not much HDTV. Also, 1.85 makes for (slightly) smaller bars for 2.35:1. So I don't see why it seems like 16:9 is the default wide format for most forum members, not 1.85...
But I don't *own* a screen (yet), so I'm just guessing!
Mike
mflaster is offline
post #3 of 8 Old 02-07-2001, 08:00 PM
DMan's Avatar
Mike,
You make a very valid point. I am actually going from a 1.85 screen to a 1.78 screen but I do view a good share of HDTV. As Steve mentioned, I am going with a Stewart Horizontal Electrimask screenwall so I can mask from 1.78 to 1.85 to 2.35 and beyond, so it's now a moot point with me.
I would however still suggest a 1.78 screen because it will not only future proof your screen for your future HDTV needs, but it is also so close to 1.85 that most of these 1.85 DVDs will likely fill the screen given a 5% amount of overscan.
DMan
The Academy Home Theater
DMan is offline
post #4 of 8 Old 02-07-2001, 09:37 PM
KFung's Avatar
My God... a 4 Way Electrimask is so far out of my league ($10k at the size of screen I wanted!). Let me know if you ever want to sell your masking cheap http://www.avsforum.com/ubb/biggrin.gif
Kam Fung
KFung is offline
post #5 of 8 Old 02-07-2001, 09:49 PM - Thread Starter
Quoted: 439 Post(s)
Liked: 100
But my screen is only 80" wide. You'd not only have to stretch your budget, but you'd have to stretch my screen to make it fit!!!!
Steve Bruzonsky
My home theater at:
post #6 of 8 Old 02-07-2001, 10:49 PM
jcpom's Avatar
For watching DVDs, which size screen would fit better, i.e., seeing less of the black bars.
jcpom is offline
post #7 of 8 Old 02-08-2001, 08:03 PM
KFung's Avatar
Steve, actually I just want your masking http://www.avsforum.com/ubb/biggrin.gif . I think I would modify it and stretch it to accomodate a larger screen. I know Stewart has a fancy arrangement for the bottom mask so that it is always in tension. Anyone from Stewart want to sell me on buying their 4 way masking as oppossed to making my own?
Kam Fung
KFung is offline
post #8 of 8 Old 02-08-2001, 10:52 PM
Ben
Ben's Avatar
Is there a significant price difference between a 1.78 & 1.85 Stewart screen? I would guess not, since they are so close to the same ratio, but I haven't compared prices between the two. I currently have a 1.78 Draper screen and am having a hard time deciding on which GrayHawk to get, 1.78 or 1.85. I probably do a little more HDTV viewing, than DVD, so maybe I should stay with the 1.78 ratio?
Ben
Ben is offline
Closed Thread Screens
