Screen material and size for new Dwin - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-09-2001, 09:23 PM - Thread Starter
michael goldman's Avatar
With the new Dwin Transvision scheduled[fingers crossed] for late this month, I am in need of help concerning screen type. It is a 1000 ANSI lumens DLP projector. I am looking at a 16:9 screen ,probably 107 inches wide. I do plan on a Panamorph. The projector would be 17 feet from screen. Is this realistic. Is it recommended to get a Grayhawk and sacrifice the brightness of the studiotek, or vica versa and gain the blacks of a Grayhawk. Do need to make a decision soon, so any help is much appreciated
Michael
tuckerdog
michael
michael goldman is offline
post #2 of 3 Old 02-10-2001, 06:47 PM
DMan's Avatar
I think the consensus is with a LCD,DLP,or D-ILA projector with a 1000ansi or higher lumen rating that the GrayHawk screen is the only way to go for a more realistic black level.
DMan
The Academy Home Theater
DMan is offline
post #3 of 3 Old 02-15-2001, 11:09 AM
David Wallis's Avatar
Someone will correct me if this is wrong, but this is how I worked out my Grayhawk/Transvision/Panamorph (except my screen is only 100")
At 107" wide on a 1:78 screen the calculation would be:
Screen = 8.9ft wide x 5.0ft high = 44.50 sqft
With Out Panamorph.
1000 Ansi's x 0.75 (light loss for black bars) = 750/44.50 sqft = 16.85 ft lamberts x 0.8 gain = 13.48 ft lamberts on screen.
With Panamorph.
1000 Ansi's/44.50 sqft = 22.47 ft lamberts x 0.8 gain = 17.97 ft lamberts on screen.
You need about 13 - 17 ft lamberts min in my view, so you ar pretty safe either way.
DavidW
[This message has been edited by David Wallis (edited 02-15-2001).]
David Wallis is offline
Closed Thread Screens
