Screen mounted on chains - will it shake? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-15-2001, 12:50 PM - Thread Starter
bryan_chow's Avatar
Due to my ceiling being higher than I expected, I'll need to mount my Stewart StudioTek 130 Electriscreen about 10 inches below the ceiling using chains (and the eyebolts provided).
Is that going to shake or sway when watching a movie? Also, will it need time to "settle" when I first lower it?
Bryan
bryan_chow is offline
post #2 of 4 Old 02-16-2001, 01:28 PM - Thread Starter
bryan_chow's Avatar
Thanks for the reply.
My screen is heavy though, and motorized. Hopefully it won't sway either.
Bryan
post #3 of 4 Old 02-16-2001, 02:10 PM
RandyL712's Avatar
Actually the heavier the screen, the less it should budge. Heavy stuff takes more power to move, right?
Oh sure. But what's the speed of dark?
RandyL712 is offline
post #4 of 4 Old 02-19-2001, 02:42 AM
KUVA's Avatar
The last four people that had mounted there screens on some type of chain or thin cable systems, that I know of, did not have any problems. Make sure to close the windows!
Trev
KUVA is offline
Closed Thread Screens
