HELP!! I need to get sticky tape goo off my screen! - AVS | Home Theater Discussions And Reviews
post #1 of 4 Old 02-21-2001, 04:51 AM - Thread Starter
Jeff Lemke's Avatar
After installing my Draper M1300 last night I noticed a stray piece of tape stuck to the screen. Upon pulling it off (not easy) it left some nasty goo. What is the best way to clean it? I am afraid of using a solvent that is too strong.
Thanks for any help.
Jeff
Jeff Lemke is offline
post #2 of 4 Old 02-21-2001, 07:24 AM
Federico's Avatar
Jeff I had use baby oil to remove the "nasty goo" that masking tape leave over plastic and vinyl when you remove it, then I use alcohol or soap to remove the oil. I would try first over another material like the bath curtain.
Federico
Federico is offline
post #3 of 4 Old 02-21-2001, 08:35 AM - Thread Starter
Jeff Lemke's Avatar
Thanks, Federico.
Jeff
post #4 of 4 Old 02-21-2001, 11:34 AM
bwolff's Avatar
I would be afraid of using anything. YIKES. Can you get it off with another piece of tape? Sometimes sticking and pulling off a piece of tape will pull up the glue. Goo gone works but I can't say what anything will do to a screen.
~~~~~~~~Bwolff~~~~~~~~
Champagne tastes with a beer budget
My Theater
bwolff is offline
Closed Thread Screens
