your elec. screen - do you use masking? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-27-2001, 07:01 AM - Thread Starter
mmcdlc's Avatar
Hey, all you electric screen users - are you using electric masking? I'm buying my first screen today or tomorrow and need to know how important masking is? Projector is LP350 from Infocus, screen probably a Greyhawk but I'm open to suggestions from Da Lite or Draper that are less expensive.
If I get a 100" 16:9 screen could most people live with the bars left and right on 4:3 material, remember the 3" light border on the 350 on all 4 sides! Why I'm posting this - the electric masking is expensive like $1500 more than with no masking. If I knew a bunch of you with electric screens get "used to " not having masking I'll use the money to upgrade to a new processor from Lexicon. But, if you all feel I'll never get used to the bars let me know - I don't want to regret the decision later.
Thanks, Dave
mmcdlc is offline
post #2 of 3 Old 02-27-2001, 11:21 AM
gordf's Avatar
Hi Dave, I have an electric Vidikron (I believe made by Stewart) and do not yet have masking. I will probably set up some manual masking.
Most people who have tried masking won't live without it. Can you set up some temporary masking before you buy the screen and try it out to check out the difference in your setup? I would have purchased one with electric masking if I'd had that option, it's a much more elegant solution.
As a Dila owner I would go with the Grayhawk tab-tensioned with masking if my instalation was 100% permanent.
gordf
gordf
gordf is offline
post #3 of 3 Old 02-27-2001, 02:10 PM
DMan's Avatar
<font face="Verdana, Arial" size="2">Most people who have tried masking won't live without it.</font>
I could not agree more!! http://www.avsforum.com/ubb/smile.gif
Dave,
For me, masking is one of those options that after you seen it's effect you will definitely want it. It makes a huge difference with light spill from digital projectors. Highly recommended!!
DMan
The Academy Home Theater
DMan is offline
Closed Thread Screens
