Calculations for Gray paint - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-28-2001, 08:51 PM - Thread Starter
adamgroth's Avatar
Does anyone know the exact percent of black in a gray (GrayHawk style) screen? What I mean by percent black is, when you create CMYK color, you start with white (ie. C=0, M=0, Y=0, K=0). You then add the various shades to create you color, in our case gray.
What I'm looking for is the number to use to create the best screen color for the VW10HT. I have heard people refer to the Kodak 18% card, but is this the same as C=0, M=0, Y=0, K=18, AND is this the same value as the new gray screens?
Wouldn't it be much easier for someone to walk into Home Depot and request a specific color value that the paint guy keys into the computer vs handing him a gray card and having him try to color match it?
Adam Groth
adamgroth is offline
post #2 of 8 Old 03-01-2001, 06:19 PM
EHUFF's Avatar
I'm not a paint scientist and don't know what the numbers mean exactly, but I ordered a quart of flat white paint from a local do it yourself center. They added 15 black. The book they had said B-15. I'm not sure if this is a percentage number. I thought it was a tad too dark so they then added more white. When he added a very small amount of white he said : "20 should do". Whatever that means.
The color that I ended up with is close to the GrayHawk gray. I think I may go back and mix to just a little lighter, because upon projection testing with my Sony 10HT the blacks look better but there is just a little to much brightness loss in the whites for my taste. I think another "20 should do." http://www.avsforum.com/ubb/smile.gif
In the end, if the B-15 is a percentage number from my case, then I would suggest about a 12% to 14.5% black added to white to get a very close to grayhawk gray. Your mileage may vary.
EHUFF is offline
post #3 of 8 Old 03-02-2001, 11:13 AM - Thread Starter
adamgroth's Avatar
Screen...what screen? I don't even have a theater room!...YET! Actually, my dedicated theater room is in progress (about 80% complete). I'm just now begining to search for options for the screen. I'm a DIY'er, so I was hoping others would have input about the paint mixture percentages.
I'll post images to my web page when all is complete!
Adam
P.S. My ref to the VW10HT is not because I have it, but because right now it looks like the winner for my taste/budget. This may change after the room is complete and I'm ready to buy. I'm trying to hold out for the new 16 x 9 DPL!!!
[This message has been edited by adamgroth (edited 03-02-2001).]
post #4 of 8 Old 03-02-2001, 11:18 AM
EHUFF's Avatar
I made a 106" 16x9 frame from 1x2's and stretched blackout curtain material around it fastening with a staple gun as I went. I then painted this surface with my gray paint mixture. It works quite well, it is very flat, taught and cost only about $36 for the entire project. Hard to beat that. BTW : I had to sand a few paint blemishes out to get a very even flat surface.
If you do a search on this forum you can find lots of information on the blackout curtain material.
EHUFF is offline
post #5 of 8 Old 03-02-2001, 06:39 PM - Thread Starter
adamgroth's Avatar
<font face="Verdana, Arial" size="2">I then painted this surface with my gray paint mixture.</font>
What was the mixture you used? Or...is it a trade secret? http://www.avsforum.com/ubb/wink.gif
BTW, I have searched the forum for the DIY screen topic and have alot of good ideas for construction. However, the color is probably the most important aspect of the project.
Adam
post #6 of 8 Old 03-02-2001, 08:55 PM
EHUFF's Avatar
See my post above for the mixture. If I can remember I'll post my brand of paint and mixture as hand labeled on the can after the weekend.
EHUFF is offline
post #7 of 8 Old 03-02-2001, 10:27 PM
Scott Gammans's Avatar
EHUFF:
What surface are you using for your DIY screen?
Scott Gammans
mail@scottgammans.com
The Official Scott Gammans Website
Scott Gammans is offline
post #8 of 8 Old 03-04-2001, 04:08 PM
EHUFF's Avatar
Okay here's what I got : Morwear premium flat vinyl acrylic 1860-01 P HI Hide White. Then I mixed as stated above.
EHUFF is offline
Closed Thread Screens
