Opinion on back projection? - AVS Forum | Home Theater Discussions And Reviews
Old 03-09-2001, 12:53 AM - Thread Starter
Gunnar's Avatar
Quoted: 13 Post(s)
I recently visited a guy who had a Stewart back projection screen. It looked almost as black as a tv-screen and the picture looked rather good even with some light in the room. I noticed some hotspotting, and some glare from the glossy (looked like glass) surface, but else this was a very elegant integration of HT in a living room. The big BG-1200 projector was ceiling mounted in the neighbouring office, and couldn`t be heard in the living room.
Any opinions on picture quality differences between front and back projection?
Gunnar is offline
Old 03-09-2001, 08:00 AM
DMan's Avatar
This sounds quite a bit like a Stewart BlackHawk Rear Projection screen. I'm sure it looked good, however I have always heard that Front Projection will almost always look better than a Rear configuration (barring any ambient light problems). Typically, with a RP setup their is a higher level of hotspotting, as well as poor off-axis viewing over it's FP counterpart.
Again, when lighting conditions are controllable, and you simply have room for the projector on your floor or ceiling, a front projection install will be preferred.
DMan
The Academy Home Theater
DMan is offline
Old 03-09-2001, 01:28 PM
noah katz's Avatar
Quoted: 887 Post(s)
Liked: 305
Hotspotting is no more a necessity with RP than FP; the same set of tradeoffs vis a vis gain/brightness/hotspotting exist. But the RP will be much more tolerant of room light.
Hotspotting and resolution loss can be avoided with a diffusion screen.
There's lots of info on RP at the Dalite and dnp web sites; a google search on "rear projection screens" will turn up their sites.
Noah
[This message has been edited by noah katz (edited 03-09-2001).]
Noah
noah katz is offline
