A screen with witch gain for a 1271Q - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-09-2001, 08:06 PM - Thread Starter
marko's Avatar
Hi everyone!
I have a Sony VPH-1271Q, and I'm just projecting on a white wall right now, I'm wondering witch gain should I go with this "low lumens" projector (the specs says 650 lumens).
I have 100% control over the ambient light.
Will 1.0 be ok, or 1.3, or should I get a high gain screen, like a 2.0 or 2.5??
Marc Behar
Marc
marko is offline
post #2 of 3 Old 03-09-2001, 09:25 PM
David Richardson's Avatar
What size screen are you looking to purchase? I have a 1252 and just bought a 84" diag 4x3 with 1.5 gain. I'm very happy with it. To me if you use a high power you lose the "film" quality of movies.
Dave
Watch HDTV!!! Nothing else comes close!
David Richardson is offline
post #3 of 3 Old 03-09-2001, 10:03 PM - Thread Starter
marko's Avatar
Hi thanks for the reply, the screen will be 92" or 106" with a 1.85:1 ratio. I'll be watching mostly DVDs from a HTPC.
Marc Behar
Marc
marko is offline
Closed Thread Screens
