repair plastic screen ? - AVS Forum | Home Theater Discussions And Reviews
Old 03-15-2001, 08:07 AM - Thread Starter
fledelius's Avatar
Hi,
I just bought a used projector, and with it came a cut-out piece of a large plastic screen (think gain 1.5 - 2)
But some brilliant mind folded it!
Is there a way to remove the folds in the plastic screen ?
I was thinking maybe a wet cloth and an iron...
thanks,
fledelius
fledelius is offline
Old 03-15-2001, 09:08 AM
sstieferman's Avatar
fledelius,
Risskov, Denmark - pretty cool place, seems to be very involved in music and software. Anyway, I was surfing the web to find out what the weather was, because I suggest that you let the sun have a go at it. I've had problems in the past with material that after a few hours in the sun you would have never know problems like wrinkles existed. Of course I live in Austin, Texas where things melt.
If you can tension the screen on a frame and place it in direct sunlight next to a window or on a patio, you might be surprised.
Hope this helps.
Scott
sstieferman is offline
Old 03-15-2001, 09:27 AM - Thread Starter
fledelius's Avatar
Impressive geographic knowledge, most people think Denmark is the capitol of Sweden !
About the weather.....
The sun has been out for about 30 minutes today, and we are just above freezing. So maybe I will find another energy source http://www.avsforum.com/ubb/smile.gif
thanks,
fledelius
