New help choosing screen!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-12-2001, 05:29 AM - Thread Starter
Joeboo's Avatar
I need some serious help. I have no idea what I'm doing.
I own a Proxima LS1 that I received for basically nothing ($450, was a demo model, hardly ever used). It is 700 lumens. The room i'm in has no ambient light at all. I plan on using an HTPC to make it 720p when watching DVDs.
My question is what fixed screen do you recommend? I don't mind spending money (but try to keep it under $1500). What gain do I get with only 700 lumens? What size should I keep it to so that the picture looks nice, but big?
Any help would be awesome. Like I said, I'm a bigtime newbie. Right now I have a Da-Lite pulldown, but I'm moving to a fixed screen.
Joe
[This message has been edited by Joeboo (edited 03-12-2001).]
Joeboo is offline
post #2 of 10 Old 03-14-2001, 05:10 AM - Thread Starter
Joeboo's Avatar
Can anyone help out?
Would going from say a Da-Snap to a Stewart StudioTek be a good idea?
Joeboo is offline
post #3 of 10 Old 03-14-2001, 07:34 AM
kelliot's Avatar
I think the projector might be too weak for a gray screen like the Grayhawk or HC DaMat. How big is the screen and can you control ambient light? I'd be tempted to try a gain 2.0.
Ken Elliott
[This message has been edited by kelliot (edited 03-14-2001).]
Ken Elliott
kelliot is offline
post #4 of 10 Old 03-14-2001, 07:42 AM - Thread Starter
Joeboo's Avatar
with the exception of a door, the light is completely zero (no windows). So no ambient light whatsoever.
I'm looking at a screen that is 52x92.
[This message has been edited by Joeboo (edited 03-14-2001).]
Joeboo is offline
post #5 of 10 Old 03-14-2001, 07:51 AM
kelliot's Avatar
Try a gain 2.0.
Ken Elliott
Ken Elliott
kelliot is offline
post #6 of 10 Old 03-14-2001, 04:50 PM
thxave's Avatar
If you are going with a fixed screen you may want to look at a lace and grommet system. Da-lite will custom cut this and put on a 2" black boarder with grommets. This screen will be ultra flat and the frame used for lacing up the screen is perfect for mounting mattes to.
I have a Da-lite High power(2.8gain) screen with this system and it worked out better than I hoped.
My HT Pics http://hometown.aol.com/thxavery/page0002.html
thxave is offline
post #7 of 10 Old 03-15-2001, 03:56 AM - Thread Starter
Joeboo's Avatar
I think the Dalite Da Snap (52x92) was like 700. The Stewart with velux was 1475.
Both do not included shipping.
Joeboo is offline
post #8 of 10 Old 03-15-2001, 04:31 PM
Gary Lightfoot's Avatar
Quoted: 824 Post(s)
Liked: 519
Hi Paul,
for good prices, try:
http://shopcousinsvideo.com/
Don't forget to add 3.5%duty, and 17.5% VAT should customs get hold of it. The Stewarts screens are the best, but very expensive here in the UK. Try http://www.ivojo.co.uk/screens.htm or http://www.direkt2u.co.uk/ for UK prices on Da-lite screens. There's also a place in Scotland - StereoStereo, but I haven't the url handy right now. The chap there (Gordon) is very helpful).
If you want to make youre own, ask for blackout cloth at your local Alders or similar. Its' a white cloth on one side, and whitish vinyl on the other. Its stops light leaking through (hence the name) and is a good cheap screen material (£5 per meter length, 54ins wide), I got 3m to make a custom size screen (I already have some wood for the frame) so I'm going the DIY route until I know exactly what screen I need for my HT room when it's finished. A lot of people here have stuck with the home made screen because it does a good job as is, and is very cost effective.
Hope that helps.
Gary
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is online now
post #9 of 10 Old 03-16-2001, 06:15 PM
thxave's Avatar
Paul, The screen I got was 70"x70" (74"x74" incl border)
Da-lite high power. It cost me about $500 US.
It is priced by Sq foot so I paid a little more than
I had too because of the size I wanted. I was not sure
how I wanted to mask it so I just got a 70"x70" screen.
It works great with the CS1,CS2.
thxave is offline
post #10 of 10 Old 03-17-2001, 07:48 PM
thxave's Avatar
Paul, I sent you some close up pics. Hope they are some help.
thxave is offline
Closed Thread Screens
