Da-Lite High Contrast - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-22-2001, 10:56 AM - Thread Starter
sonny b's Avatar
This High Contrast fabric, is it a new variation of the Da-Mat or is it a totally new fabric from Da-Lite? I checked the Da-Lite website and they only list the Da-Mat.
From what I read in some posts, it's color grey. Is this Da-Lite's answer to the Greyhawk? Would it be a good match for the LP340 or VT440? What about for a 700 lumen projector like Sanyo's SW10?
Anyone with comments, please chime in.
Tnx - Sonny
P.S. Tried to do a search on this subject but the server was busy so I'm not sure if this topic has been brought out before.
[This message has been edited by sonny b (edited 03-22-2001).]
sonny b.
sonny b is offline
post #2 of 4 Old 03-24-2001, 12:10 AM
Bulldogger's Avatar
Quoted: 235 Post(s)
Liked: 55
It is a new fabric. Contact Da-lite and ask for some samples. It is .80 gain instead of .85 that the Stewart grayhawk uses. It works very well. I have a tensioned high contrast screen in the cosmopolitian electrol version. The fabric only is availible on fixed or tensioned screens. Da-lite recommend it for projectors with around a 1000 lumens like the Sony vh10 which is what I used for a demonstration. I was not able to directly compare it to the Stewart grayhawk as the dealer did not have one. But from the results I obtained, I did not need to compare it.
Never become so involved with something that it blinds you.
Bulldogger is online now
post #3 of 4 Old 03-24-2001, 03:04 AM - Thread Starter
sonny b's Avatar
Would this be a good match for the LP340 or the VT440?
- Sonny
sonny b.
sonny b is offline
post #4 of 4 Old 03-25-2001, 06:21 AM
Bulldogger's Avatar
Quoted: 235 Post(s)
Liked: 55
The LP340 has 1300 lumens, more than enough for use with the da-lite high contrast. I am not familiar with the VT440. Because of the low gain of the screen it is intended to be used with projectors with at least 1000 lumens. Da-lite does however recommend that your screen be located in a dark area of the room with little ambient light directly hitting the screen for best results. If you have a lot of ambient light,da-lite recommends a screen with a higher gain. You are going to have to take a look at the materials and see which you prefer. I loved the increased black level I saw when I examined the high contrast with the Sony.
Closed Thread Screens
