prices - AVS Forum | Home Theater Discussions And Reviews
Old 03-25-2001, 02:09 PM - Thread Starter
GilR's Avatar
Hi Paul,
You'll probably spend about $1200.00 for a Stewart and the Grayhawk is not an additional charge. You can find cheaper but you wont find better, thats for sure. Email Jason at AVS and he can give you a quote. Very helpful.
Good Luck
Gil
GilR is offline
Old 03-25-2001, 09:45 PM
Paul B. Musser's Avatar
How much would one expect to pay for a Stewart Screen 16:9, 1.3, 92" fixed screen? Is there a premium for the grayhawk material? Are Da-lite and others cheaper?
thanks,
Paul
Paul B. Musser
nospam@nycap.rr.com
Paul B. Musser
Visit Loudon Theater at:
http://home.nycap.rr.com/pbm1/loudon.htm
Paul B. Musser is offline
Old 03-26-2001, 06:49 AM
hvn4179's Avatar
My own experience. The manual pull down, 110D, Dalite hipwr cost $400. Similar size for Greyhawk is $1700.
Hugh
hvn4179 is offline
taboola here
