Stewart vs. Draper vs DNP rear projection screens? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-23-2001, 12:40 PM - Thread Starter
Christopher Calder's Avatar
Is the Stewart "Opta-Wave" rear projection screen the same as the Draper (made by DNP) "Diamond screen"?
Which is better? Which is cheaper? Is there anything better?
http://www.stewartfilm.com/engineeri.../optawave.html - Stewart
http://www.draperinc.net/RearProject...mondScreen.htm - Draper
I cannot find a decent DNP Web site in English. Anyone have their URL?
Christopher
Christopher Calder is offline
post #2 of 5 Old 03-23-2001, 08:13 PM
noah katz's Avatar
Quoted: 1032 Post(s)
Liked: 366
Christopher,
http://www.dnp.dk/
Be prepared for sticker shop ~$10K for an 8' screen.
About six mos. ago there were some posts on a new 3M rear screen material, very high contrast and resistance to ambient light. It'a called Glasfire; here's the only info I saved on it:
Check www.graybow.com. They are the exclusive dealers and have been for
only 4 weeks. (They worked the prototyping along with 3M.) Because it
is so new for them, I doubt you'll find it on their website. If you
want more information ask for Wendy 952-543-1565. PLEASE tell her that
J.R. from Turfboard sent you.
J.R. saw it and said it looked great in broad daylight, with a 1000-L DLP, if I remember correctly.
Noah
Noah
noah katz is online now
post #3 of 5 Old 03-24-2001, 01:22 PM
noah katz's Avatar
Liked: 366
Forgot to mention that the Glasfire is much cheaper, too, ~$3K in that size range.
Noah
Noah
post #4 of 5 Old 03-24-2001, 07:02 PM
Don Stewart's Avatar
Quoted: 107 Post(s)
Liked: 109
Rear Projection screens are rarely discussed in this forum. I am going to take this opportunity to to make a few comments.
Most rear screen technology come from two different manufacturing process. One is called "Optical Lens" type screens" and the other is "Diffusion" Type screens. Their are some other types too: Light Pipe, Embeded Glass Bead but have yet to make much of an impact on the market. The optical lens screen are manufactured by a casting process. Each side of the screen has a separate lens pattern. The projector side of the screen has a Fresnel lens. Each circular ring on this lens has a different calculated pitch which collimates the projected light through the screen. (A side note here: When purchasing a optical screen, one should match the focal length of the projector lens with the focal length of the screen's fresnel lens). On the optical screens viewing side there is a Lenticuar lens. The primary job of this lens is to distribute the collimated light in the horizontal viewing axis. With this highly light efficient type screen design, rear lens type screens can be made over 5 gain. These high gain screens are employed within systems requiring large images with CRT projectors. Also, with extreme ambient light, like behind a news caster on TV set, lens type screens are used with a high lumen output digital projectors. The cost of these giant lens screens are between 6 and 9 K for a 100 inch four by three AR. The maximum size available Lens Screens are 200 inches diagonal.
The most commonly used Diffusion rear screens run from about 1 to 2 gain. At the risk of over simplifying how a diffusion rear screen works, take a translucent substrate, lets say tracing paper and place it in front of your projector. You will see somewhat of a diffused image. Professionally manufactured diffusion screens use different types of tiny particles suspended in a film to diffuse the projected image. The screen's gain, vertical and horizontal viewing axis, color temp, contrast, etc, will vary depending upon the films formulation. Diffusion screens come in flexible models along with rigid acrylic and glass substrates models. The MSRP price for a 100 inch RP diffusion screen will range from $400.00 to about $2,200.00 The flexible type screen can be manufactured in sizes over 100 feet for large venues. The rigid types rarely exceed 25 feet in width.
Don
[This message has been edited by Don Stewart (edited 03-24-2001).]
Don Stewart
Manufactures of Precision Professional Projection Screens.
http://www.stewartfilmscreen.com/
Don Stewart is offline
post #5 of 5 Old 03-26-2001, 12:23 PM
rbmartin's Avatar
<font face="Verdana, Arial" size="2">A side note here: When purchasing a optical screen, one should match the focal length of the projector lens with the focal length of the screen's fresnel lens). </font>
Don:
In most home theater setups where we're sitting close to the screen, wouldn't it be better to have the screen's focal length somewhat shorter than the projector's focal length? In theory this would direct more of the light toward the viewer. Just wondering if theory agrees with practice.
Richard
by the way, Christopher, DNP's web site is www.dnp.dk
[This message has been edited by rbmartin (edited 03-26-2001).]
rbmartin is offline
Closed Thread Screens
