How do I clean a rear projection screen?? - AVS Forum | Home Theater Discussions And Reviews
Old 03-20-2001, 05:53 PM - Thread Starter
gn2
gn2's Avatar
I just bought an Electrohome Retro, which is just a big rear projection tv with an ECP-4100 crt projector inside. The screen is textured and seems to have a couple of stains on it, how can I clean this textured plastic screen? If I can't clean it effectively, where can I get a cheap/and/or better replacement? Are there any plastic architectual products that can be used as a screen?
Thanks, Paul.
gn2 is offline
Old 03-24-2001, 11:06 AM - Thread Starter
gn2
gn2's Avatar
Anyone? Come on there must be someone out there who knows something about rear projection screens?
Thanks, Paul.
gn2 is offline
Old 03-25-2001, 11:14 AM
KBK
KBK's Avatar
Invite me over to see the GP projector. I'll take a look at it, and we should be able to come up with something other than spray 9 and steel wool.
goosystems.com
Ken Hotte
kbk@cyberfreak.dhs.org
Ken Hotte
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge.
KBK is offline
Old 03-27-2001, 01:41 PM
Donald Bennett's Avatar
All I ever used is water and a soft lint free cloth.
Don
Donald Bennett is offline
Old 03-27-2001, 07:10 PM - Thread Starter
gn2
gn2's Avatar
The water and lint free cloth has had a try, as has a soft brush and mild warm soapy water. Whatever is on the screen, you can see that it is in the tiny grooves, and stubbornly attatched!
Thanks, Paul.
gn2 is offline
Old 03-30-2001, 10:27 PM - Thread Starter
gn2
gn2's Avatar
I solved my own problem, and in case anyone else has a rear projection screen with coffee, or tobacco tar, or some other noxious substance in the grooves of the screen, just use baking soda, hot water, and a soft tooth brush. It cleaned the stain, and seemed to polish the surface slightly.
Thanks, Paul.
gn2 is offline
