DALITE Model B 69x96 screen has waves in it!?? Anybody else? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 02-19-2001, 09:51 PM - Thread Starter
power's Avatar
I have lived with this screen since i got it about 6 months ago and now that i am properly set up with high definition television and a HTPC on the way i simply cannot take it anymore! The screen material is nice, the 1.5 gain material but there are a few waves/wrinkles in the screen and am wondering if anyone else has a similar problem. I know this should not be a common problem, i thought about getting some type of tensionner(s) or something but i remember that even in high school with the cheap classroom pull down screens, there were never any waves in them. Now i have a great picture but the flaws in the screen is a real annoyance especially on certain scenes (blue skies, light colours, white). Got to fix this PROBLEM. Anyone that could be of assistance i would appreciate it. Regards
power
Serge Breton
htauthority.com
Home Theater Authority
power is offline
post #2 of 14 Old 02-20-2001, 08:19 AM
wireburn's Avatar
I have heard of pulling on the ends of the lower rod to fix the Model B. I have the HP material in this size. It's nice and thick, so there is only the slightest 'V' shape which in indetectable from the viewing position.
-Mike
I didn't do it
Nobody saw me do it,
You can't prove a thing
An Haiku by Bart Simpson
wireburn is offline
post #3 of 14 Old 02-20-2001, 05:56 PM
rsandor's Avatar
Exact same problem. Just bought mine a couple of weeks ago and just set it up. The waves look like they originate from the top of the roller. I was about to write to DALITE to ask about if there are any fixes. Otherwise, I am going to have to return the unit...
rsandor is offline
post #4 of 14 Old 02-20-2001, 09:16 PM - Thread Starter
power's Avatar
yeah, i purchased mine from the States and am not sure on how i could get a replacment for my faulty screen. Something must be done though!
power
Serge Breton
htauthority.com
power is offline
post #5 of 14 Old 02-20-2001, 09:49 PM - Thread Starter
power's Avatar
My problem isen't towards the bottom, it is at the top where the wrinkles are and these carry into waves all the way down the screen. So instead of a nice flat surface i see 3 large waves running vertically. I dont expect this from a manufacturer like Da-lite, the more i think about it the more it drives me nuts. This problem definitely takes some of the enjoyment out of watching movies on my projector.
power
Serge Breton
htauthority.com
power is offline
post #6 of 14 Old 02-21-2001, 04:38 AM
wireburn's Avatar
For problems with wrinkles originating at the top, I've heard of inserting several sheets of paper between the roll and the screen in the middle to help straighten them out.
-Mike
I didn't do it
wireburn is offline
post #7 of 14 Old 02-22-2001, 07:19 AM
DRS
DRS's Avatar
EXACT same problem!
Here is a copy of the email I just sent Da-Lite,
"I have a 57x77 Model B High Power screen that has a problem. There is a dark vertical band that is approx. 6 inches in diameter that runs the entire height of the screen. This band is located about 1-2 feet away from the left side of the screen. It is most easily seen during dark scenes. The screen was purchased from Cousin's Video in Mentor OH on 10-26-00. Thank you for your assistance with this matter."
System info: Native XGA LCD FP, Dalite 57X77 HP, P3 700, ATI Radeon, Cinemaster 2k, WinDVD 2.6.4, WinME
DRS is offline
post #8 of 14 Old 03-28-2001, 08:10 AM
derek's Avatar
Quoted: 14 Post(s)
Any updates from da-lite or fixes here?
Derek
Surround EX FAQ: http://www.geocities.com/Heartland/P...urroundex.html
Derek
derek is offline
post #9 of 14 Old 03-28-2001, 10:34 AM
hvn4179's Avatar
My hipwr, 110"D, screen has a couple "slight" waves on the left and right sides. After couple hundred hours of usage, it didn't bother my eyes neither I can see the picture distortion at 11' away. I thought this is a normal occurence for model B because the lacking of backing/tensioner.
Hugh
hvn4179 is offline
post #10 of 14 Old 03-28-2001, 11:04 AM
Skipper's Avatar
Same problem here!!!
Got my 68" (172cm.) wide model B Da-lite three months ago, and it has four FOUR of the most wonderful stripes from top to bottom.
It's so bad, that everything that passes the stripes seems to bounce up an down.
The first two screens I recieved vas damaged on the screens "coating", the third was bend, and now this!!!!
I can only urge any Da-lite reps. to find a solution on this soon. Or my screen goes back to the dealer.
Regards
Skipper
Skipper is offline
post #11 of 14 Old 03-28-2001, 08:24 PM
yowzah's Avatar
I'm glad I ran across this thread! I've been on the fence about building a DIY screen or buying a model B. A 69x96 model B was looking good for the price ($170 or so), but now it doesn't. Does anyone know if the other screen manufacturers have a similar problem, preferably Draper?
yowzah is offline
post #12 of 14 Old 03-29-2001, 07:06 AM
aras's Avatar
I also have a Dalite model B in a standard 8 ft diagonal size and it too has the verticle waves , that slightly distort the picture . I looked from the side and WOW it looks like an ocean scene of waves.
aras
aras is offline
post #13 of 14 Old 03-29-2001, 08:37 PM - Thread Starter
power's Avatar
wow,
i can't believe my post is still here, i am getting a replacment from Dalite since the screen is under warranty, avoid the model B 1.5 gain screen, this material is more succeptible to wrinkles vs the matte white version for example.
power
Serge Breton
htauthority.com
power is offline
post #14 of 14 Old 03-30-2001, 09:58 PM
adarsh's Avatar
Sorry to hear about your problems with Model B.
I have Da-Lite Model B video speactra 1.5 52"X92" format.
No problems with mine. Great Picture and Awesome Color
Adarsh
adarsh is offline
Closed Thread Screens
