screen size for NEC 135 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-31-2001, 08:47 AM - Thread Starter
Brian Steg's Avatar
I am awaiting shipment of an NEC 135 LC purchased from AV science. I am trying to decide on a size for a Stewart Screenwall Studiotech 130. The room is 16 x 24 and the seating is about 14 feet back from the 16 foot wall where the screen will be mounted. The room can be made completely dark. Any suggestions ?
Brian Steg is offline
post #2 of 3 Old 03-31-2001, 03:31 PM
Jim Ferguson's Avatar
I have had a 92x52 Da-Lite, and currently have a 96x54 Stewart Studiotek 130. I don't think you would want to go any bigger than that with a CRT projector. I would probably go with the 92x52 if I had it to do again.
Jim Ferguson is offline
post #3 of 3 Old 04-04-2001, 02:02 PM
FAR64's Avatar
Brian,
I have the same projector in my theater which is 16'x20'. I am using a 107" x 60" Stewart Studiotech 1.3 gain screen. The picture looks fantastic IMO.
I have brightness at 61 and contrast at 55 (used to set it at 60 but cut it back to improve detail in bright scenes). The signal is coming from a Toshiba SD6200 Proscan DVD player through an Extron Transcoder to the projector. From my viewing distance of about 16.5' (front of reclining seats are 14' from screen) scan lines are not apparent with anamorphic dvds. They are slightly obvious with non-anam. dvd's in bright scenes, but that is no big deal since most stuff today is anam. I use to have a 2.0 gain screen but didn't like the hot spotting and color shift with some scenes. Believe me, you don't need a 2.0 gain screen. 1.3 is plenty and it produces a much better picture. The projector puts out plenty of light.
You'll find that on a screen this size, some dvd's may look soft. That however is the result of the DVD quality and not the screne or projector. Check out Dinosaur or Red Planet and you'll see just how good your system is. You will love what you see if the projector is set up properly.
FAR64 is offline
Closed Thread Screens
