How low can my screen be?... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-09-2001, 10:41 PM - Thread Starter
Joshua's Avatar
Hi. I am considering a switch to an electrical screen, but this will take away an extra 6-7 inches to the height of my screen (100"x54", 1.85:1 @ 14ft viewing distance) which is right now at about 31 inches off the floor. Is 20-23" of the floor high enough for my viewing enjoyment?... I can't quite picture it and I have to order without prior experimentation... Any feedback would be appreciate it.
Joshua
Joshua
Joshua is offline
post #2 of 5 Old 04-10-2001, 09:22 AM
Mark Lopez's Avatar
Joshua,
Someone else asked about this here http://www.avsforum.com/ubb/Forum9/HTML/000135.html .
Can you not just lower your current screen temporarily? Or perhaps just adjust the projector (even if off the bottom) to get a feel for viewability and possible projector issues (keystoning).
[This message has been edited by Mark Lopez (edited 04-10-2001).]
Mark Lopez is offline
post #3 of 5 Old 04-10-2001, 09:35 AM - Thread Starter
Joshua's Avatar
Thanks for the link Mark.
My current screen is still in the box and is a on-wall screen. And the projector is not yet installed. So either way, I cannot experiment. This is based on last minute changes in my HT set-up (new speaker array, with an "audiophile" emphasis< so I want the screen to disappear and the cabinetry that was designed to hold a fixed screen to go as well).
I had been wondering if there was a formula to determine minimum screen height from a certain viewing distance, at a normal seating level -knowing that everybody's different, etc. Looks like the 24 to 36" high is possible in my case. I will, however, go through measuring
cnetre of screen vs position of eyes when seated to see if it works out...
Thanks again.
Joshua
[This message has been edited by Joshua (edited 04-10-2001).]
Joshua
Joshua is offline
post #4 of 5 Old 04-10-2001, 09:44 AM
Mark Lopez's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Joshua:
My current screen is still in the box and is a on-wall screen. And the projector is not yet installed. </font>
Yeah, I guess that would make it difficult. http://www.avsforum.com/ubb/wink.gif
Maybe you can fashion a temporary screen out of a sheet or something just to get a feel for how much head bending will be involved from your seating position.
post #5 of 5 Old 04-10-2001, 09:54 AM - Thread Starter
Joshua's Avatar
You're right, Mark... I've just been pretty busy theses days and was looking to maximize my HT-allocated free time to find the best solutions with the least effort! (thanks to you, Mark, and the forum http://www.avsforum.com/ubb/smile.gif ).
The thread was helpful... These are excitng last minute changes I am going through (new speakers, upgraded audio set-up, hence I want the screen to disappear and the speakers to take over when not watching a movie), but I am still trying to minimize additional (I'm already way over budget) expenses...
Joshua
Joshua
Joshua is offline
Closed Thread Screens
