Projecting on to walls - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-04-2001, 10:47 PM - Thread Starter
John Joosten's Avatar
Hi,
I am very new at this , I would like to know the best paint to paint the walls with to project on to. Could I make a screen out of 12mm mdf and paint it.
Thank you
JJ
jj
jj
John Joosten is offline
post #2 of 9 Old 04-04-2001, 11:44 PM
Vic C's Avatar
Hi John,
Its me VR AUDIO SYSTEMS again.
DONT use the bare MDP please...............If you want there are 2 home made considerations I have made........
1. use mate white formica and laminate it to at leat a 1/2" thick piece of MDF.
2. if a HOME DEPOT is availabe to you go to idea 3
3.HomeyD sells a KILLER drop cloth. It is raw canvas on the back and it is sealed, the front is this AWSOME mate white material BETTER then any projection screen I have ever seen. The drop cloth has a seem in the center but dont panic. There is enough material to make 2 100" 4:3 screens from 1 cloth. (I am using this my self) We have compaired it here on the forum and trust me it REALLY is better then a lot of screens on the market. The picture is very detailed and the color is excelent.
REMEMBER: home depot.......painters drop cloth 9 X 12 foot canvas. It is slightly gray on the back may have some black streakes nut the front ( screen side) is BAD ASS. its in a poly bag with blue lettering it sells for under 20 bucks.
This WILL work better then any paint over the counter!!! and it is way less work
Vic C is offline
post #3 of 9 Old 04-05-2001, 09:16 AM
TGroom's Avatar
Check out this thread. http://www.avsforum.com/ubb/Forum9/HTML/000183.html
This will give you a good idea about what people are doing with homeade screens. Happy reading. http://www.avsforum.com/ubb/smile.gif
Tim
TGroom is offline
post #4 of 9 Old 04-06-2001, 02:35 PM
niggenz's Avatar
VR,
Any chance you have a SKU or UPC number on that item? It would make purchasing it easier and take out the guess work of shopping at the notoriously horrendous customer unfriendly place.
HTPC: Intel NUC (DC53427HYE) running OpenELEC/Win7 Dual Boot
Projector: Optoma HD131Xe
Receiver: Onkyo TX-NR809
Screen: Elite Spectrum Electric 125"
Media Server: NAS4Free Core 2 Quad 2.40GHz
niggenz is offline
post #5 of 9 Old 04-06-2001, 08:01 PM
Vic C's Avatar
Niggenz,
I actually do have the SKU# it is :076063824006 it sells for $18.97
I hope you can find one and use it. It works awsome for my SONY CRT
Vic C is offline
post #6 of 9 Old 04-08-2001, 12:48 AM
brzez's Avatar
Where is the seam in this cloth? On the 12 foot or 9 foot side?
Thanks..
-- John
[This message has been edited by brzez (edited 04-08-2001).]
brzez is offline
post #7 of 9 Old 04-08-2001, 04:11 AM
pcdoctor's Avatar
Just curious, I have already purchased curtain blackout fabric from www.joann.com (purchased from a local Joann's Fabric in Atlanta) but I wanted to know more.
I went by Home Depot some time ago and did see a drop cloth that fit this description.
I wonder what's the difference between these two drop cloths from Home Depot?
9'x12' drop cloth - SKU# 076063824006 $18.97
Quote from VR Audio Systems
http://www.avsforum.com/ubb/Forum9/HTML/000933.html
vs
9'x12' butyl/ruber drop cloth - UPC code 047034803115 $20
Quote from sstieferman
The screen is a poly drop cloth, white - Home depot, 20 bucks.
http://www.avsforum.com/ubb/Forum9/HTML/000688.html
http://www.geocities.com/sstieferman/
http://www.geocities.com/sstieferman/pics/screen5.jpg
My HT
pcdoctor is offline
post #8 of 9 Old 04-09-2001, 07:45 PM
Vic C's Avatar
BRZEZ, The seem runs dowm the center horozontally 12"
If you cut the cloth using it as a guide there is enough material to make a 100" 4:3 screen http://www.avsforum.com/ubb/smile.gif
PCDOCTOR,
I dont know what the differance would be? I guess you could say the finish is a type of butile rubber? I am not sure. It is KICK ASS for a PJ screen though!!! http://www.avsforum.com/ubb/smile.gif
Vic C is offline
post #9 of 9 Old 04-11-2001, 04:26 AM
Endymion's Avatar
A warning about the home depot drop cloth. Not all samples have the seam down the middle. I grabbed one and it has two seams instead of one, creating 3 panels about 49 inches by 9 feet... but at this price, who cares? http://www.avsforum.com/ubb/smile.gif
John
John
Endymion is offline
Closed Thread Screens
