AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Screens (http://www.avsforum.com/forum/23-screens/)
-   -   Has anyone tried the Rosco grey screen material (http://www.avsforum.com/forum/23-screens/19611-has-anyone-tried-rosco-grey-screen-material.html)
RobertWood 04-11-2001 06:48 AM
I was just made aware of the inexpensive Rosco screen material.
Since using "grey" screens is now all the rage with high lumen
digital projectors the obvious question arises. Is the
Rosco "grey" screen something that's suitable to achieve
the same effect? Has anyone tried it?
Bob Wood
~~The Sultan of Cheap~~
Martin P 04-11-2001 04:17 PM
Never heard of it. Do you have any more info?
Ron H 04-12-2001 08:07 AM
How about a link?
Ron H
Lex/MC1, Cinepro, SL3, Logos, Tripoles, Sony 10HT, GrayHawk screen.
hsitz 04-12-2001 10:48 AM
<font face="Verdana, Arial" size="2">Originally posted by Ron H:
How about a link?
</font>
You can get info about Rosco screen material here: http://www.rosebrand.com/screens/rearsc.htm
You can also go to the Rosco site and drill down for some similar information: http://www.rosco.com
Their grey rear projection material is targeted at theatrical set applications. It's a vinyl material that can be bought in 55" bolts for $16/yard, or in wider bolts (84"?) for $70 or so a yard. I have a small sample but it's hard to tell how it would look on a bigger screen. -- Herb
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
