Size & perforation question - Page 2 - AVS | Home Theater Discussions And Reviews
Old 04-24-2001, 05:27 AM
jkv
jkv's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Dennis Erskine:
A proper acoustically transparent screen will not produce noticable problems at a correct (or further) seating distance (and a 35 degree subtended angle is excellent for a line doubled picture (or HDTV). Actual measured light loss is in the 8%-10% range. Make certain there is nothing reflective behind the screen.
</font>
I have a Stewart MicroPerf 2.0 screen; I painted the entire area behind the screen flat black in order to minimize any light reflections.
Riverside Cinemas
jkv is offline
Old 04-24-2001, 05:35 AM
jkv
jkv's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Dean McManis:
Guys,
I'm toying with the idea of getting a perforated screen too, but I do have the concern that with the speaker close to the screen fabric that there may be visual distortion due to the close proximity of sound vibrations blurring the pitcure.
Has anyone with a perforated screen tried this out or had problems with this? It's just something that I read, so I'm checking to be sure.
-Dean.
</font>
My center is 5" behind my screen; I have never noticed any problems with screen vibrations due to the center speaker placement.
Riverside Cinemas
jkv is offline
