Does $1,000 screens really makes a difference? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-01-2001, 10:14 AM - Thread Starter
alberich's Avatar
I know that this might be a stupid question but I was just wondering. I have a PJL830 (Davis 450 clone) projector and I am using a Da-Lite Matte White screen. will I really see a big difference if I were to spend over a thousand dollar in a screen compare to the $ 135.00 that I paid for the one I am using now?
Dennis
alberich is offline
post #2 of 2 Old 05-01-2001, 12:20 PM
KBK
KBK's Avatar
Yes. It all depends on what you are buying. there are cheaper ways to get to that higher grade screen than spending the $1000, though. It all depends on whether or not you wish to do a bit of work yourself....
goosystems.com
Ken Hotte
kbk@cyberfreak.dhs.org
Ken Hotte
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge.
KBK is offline
Closed Thread Screens
