AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Screens (http://www.avsforum.com/forum/23-screens/)
-   -   Screen aspect ratio follow-up (http://www.avsforum.com/forum/23-screens/19679-screen-aspect-ratio-follow-up.html)
Robster1958 05-17-2001 12:45 PM
is there any advantage to going for "standard" size of 96 x 54 (16:9) rather than 100" x 54" (1.85:1).
if i wanted to maximize image size of "normal" widescreen movie from dvd source, the i assume with the bigger screen, i end up with full width of 100" and full image height of 54", and 1" top and bottom of black bar.
then when i switch to hdtv (or stretch regular satellite), i will end up with 1" of projected image on top and bottom. this should be absorbed by the 3" velux border like overscan...right?
and for regular 4:3, my projected image will be 75" x 56"
with a viewable image of 75 x 54...again with 1' top and bottom "overscan"
does this make sense?....or am i asking for trouble?
arrow 05-20-2001 02:20 AM
Rob,
I'm not completely following you.
96x54 is 16:9 = 1.78.
If you were to display 1.85 ratio on that screen, the dimensions would be 96x52. The height gets smaller and you would need a 1" mask to cover.
4:3 comes out to be 72x54. So you need 12" masks on each side of the screen.
My opinion is to definitely go with a 1.78 ratio screen. If you go with 1.85, then you will not be able to view 1.78 material without adjusting your zoom and having borders all around the image.
--Les
DMan 05-20-2001 08:25 PM
To be real honest, you might as well use a 16:9 screen because virtually all 1.85:1 DVDs will fill your entire 16:9 screen anyway due to the amount of overscan of the image.
DMan
The Academy Home Theater
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
