need anamorphic screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-24-2001, 04:38 PM - Thread Starter
Zee
Zee's Avatar
hi everyone
I just ordered the nec lt 150 and am shopping around for a screen .. I am looking for a anamorphic size ( 54" x 126" ) with black bars on the side so I can bring it to hdtv ( 54" x 96" ) .. so I guess I am looking for a constant heigth type of a screen .. it has to be pull down since it is gonna cover a door .. is there such a thing .. thanks so much ..
ps .. I will be using this strictly with HTPC and using YXY software to control my aspect ratio ..
thanks
Zee
Zee is offline
post #2 of 4 Old 05-26-2001, 05:12 PM - Thread Starter
Zee
Zee's Avatar
thats exactly what I'm trying to do ..
anyone out there .. why is it so hard to find a pull down 2.35.1 screen ....
any help is greatly appreciated
thanks
Zee
Zee is offline
post #3 of 4 Old 05-26-2001, 09:07 PM
Dan Hitchman's Avatar
Quoted: 3561 Post(s)
Liked: 1905
So you're looking for a 2.35:1 ratio screen that can be matted to 1.78:1? Good question.
I think Stewart can do custom sizes, but I don't think you can do that ratio in a drop down style, just fixed.
It may be expensive.
Dan
STOP DFAST and The MPAA!!
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #4 of 4 Old 05-26-2001, 10:00 PM
KFung's Avatar
I don't think it should be a problem to get a 2.35:1 pull-down screen...Stewart custom manufactures all of their screens so it shouldn't cost much more (if anything). Why don't you give them a call? There's no reason why 2.35:1 shouldn't work in a pull-down.
Kam Fung
KFung is offline
Closed Thread Screens
